How many can be connected
How many pcan-usb can be connected to one pc?
Re: How many can be connected
the driver 4.x supports up to 64 channels, the API from the PCAN-Developer 4 package supports up to 64 channels, the free available PCANBasic API supports up to 16 channels.
Thanks for the quick reply.
I need to use 5 PCAN-USB. Is there any problem with USB power in this case? Please advise for stable use.
you could use an external powered USB hub, if your PC is not able to handle 5 PCAN-USB modules at the same time. But this is depending on your PC and the used USB hostcontroller of that system.
