Linux reboot PCan configuration
Hello everybody,
I have detected a difference between PCan View on Windows and Linux, maybe you can help me to understand which is the difference and how can we avoid it.
Well, in both systems we can configure a specific configuration for PCan device:
- Clock frequency
- CAN FD or not
- Nominal bit rate
- Data bit rate
- Filter settings
Once we put this configuration, we can close the application and if we open again the application it keeps the same configuration.
However, if we reboot the OS the behavior is different because on Windows it keeps the same configuration but in Linux, this configuration is reset every time.
Can you help me with that, please? I need this configuration is keeping and doesn't change on Linux.
Víctor
- Clock frequency
- CAN FD or not
- Nominal bit rate
- Data bit rate
- Filter settings
Víctor
- S.Grosjean
- Software Development
Re: Linux reboot PCan configuration
When the pcan driver is (re)loaded then the bitrate settings are reset to their defaults. The pcanview application simply displays them. If you want to set a specific bitrate to a specific device, you might use the command line. For example:
This command launches pcanview to watch the 1st channel of the PCAN-PCIe FD device, selecting its 80 Mhz clock and the 1Mbps bitrate (see also $ pcanview --help).
Another workaround would be to change the default bitrate of the pcan driver (see modules parameters "btr0btr1", "bitrate" and "dbitrate").
./pcanview -b 1M -c 80M /dev/pcanpcifd0
— Stéphane
Hello Grosjean,
Thanks for your quick answer.
I see we can change configurations like bitrate, clock, dbitrate and so on. I would like to know if we have the possibility to establish a previously "sample point" value from parameters. I haven't seen anything related to these parameters, probably you can guide me a little bit to change these specific values.
Another time, thank you very much.
Víctor
Víctor
- S.Grosjean
The reason is that you don't run the last version of pcanview-ncurses. Please send an e-mail to linux@peak-system.com, asking for the last version of pcanview-ncurses for linux. Please include the outputs of:
in the body of your email and then we will send you the corresponding debian package.
$ uname -a
$ cat /etc/os-release
— Stéphane
Hi! Can someone help me please?
How do I configure the clock?
The settings on Ubuntu: When I try to change it with "pcanview --clock 240000" this screen opens:
The Cerbo GX settings I'm trying to communicate with Ubuntu:
I'm not sure but I think the communication doesn't work due to the clock!
equipment layout:
On the PCAN-USB the Can-L is connected to pin 2 and the CAN-H to pin 7
Cristian
equipment layout:
Cristian
first of all, please don't post your issue in an existing thread, please use a new topic next time!
To use pcanview for Linux your have to install the peak-linux-driver in chardev mode, with the kernel SocketCAN driver it is not possible to use pcanview. Please see all details here:
http://www.peak-system.com/fileadmin/me ... /index.htm
Hi, sorry for posting in the wrong place.
But is it possible to change the PCAN-USB clock?
The option to change does not appear in the PC-VIEW software
I tried to communicate from windows - Cerbo GX (I couldn't install the driver on Linux)
setting the clock frequency is only possible with CAN FD devices (PCAN-USB FD, PCAN-USB-Pro FD, PCAN-PCIe FD, etc.), the PCAN-USB for CAN 2.0 has a fixed clock frequency of 8Mhz.
