Hello the team, hello all.
I need, in my project, to replace unused bytes 0x00 to 0x50.
frame example : 0100001f010000000000000000000000000070785a698a55000090785a698a55000090785a698a55000000000000000000000000000000000000000000000000
Could I find anywhere, a simple c++ example?
Thanks the team.
Vincent
frame padding c++ example
Re: frame padding c++ example
For example, the last 20 bytes...
Sorry - but we do not know what you are talking about...
- Which API
- Which Function
A CAN Frame do not look like you descripe. A CAN Frame have a ID, MsgType, DLC/LEN, and some Databytes (or none)
If you want support - aks in a way that all understand what you exact talking about
- Which API
- Which Function
Hello, sorry for explication..
Testing again
In my c++ code, Ubuntu 20.04, pcanbasic api, Peak M2,
I built a frame FD, containing 32 bytes.
_tx_msg.id = 0x8000 | id;
_tx_msg.length = 32;
// Write Mode
_tx_msg.data[0] = 0x01; // Write uint8 (0x00) | Write 1 register (0x01)
_tx_msg.data[1] = 0x00; // Register to write: MODE
_tx_msg.data[2] = 0x0A; // Value to write: POSITION MODE
// Write command
_tx_msg.data[3] = 0x0C; // Write floats
_tx_msg.data[4] = 0x06; // Write 6 registers
_tx_msg.data[5] = 0x20; // Starting register: POSITION_COMM, VELOCITY_COMM, FFTORQUE_COMM, KP_SCALE, KD_SCALE, MAX_TORQUE
// Query
_tx_msg.data[30] = 0x1F; // Read floats (0x1C) | Read 3 registers (0x03)
_tx_msg.data[31] = 0x01; // Starting register: POSITION, VELOCITY, TORQUE
Data[6-29] are feeded anywhere else.
When I read this frame, I read a 64bytes frame, with the last 32 bytes as 0x00
The controller must read unused bytes as 0x50 and not 0x00
Can I limit frame to my need : 32 bytes? Or can I pad : replace the last 0x00 to 0x50 (any code example?)
Testing again
// Write Mode
// Write command
// Query
When you read or write a CAN Frame from the PCAN-Basic API, you always have to check:
- return value of the read / write Function - must be CAN_ERROR_OK
- the Message Type must be corect (sending) or must be checked (reading)
- The DLC or LEN (DLC is not the same as LEN when using CAN-FD !! See Documentation !!) must fit
You only use the DataBytes that are valid - see DLC/LEN ! it is a differnet !
Here a sample code to convert from DLC (0..15) to real Data Bytes LEN (0..64)
// Represents a PCAN message from a FD capable hardware
typedef struct tagTPCANMsgFD
DWORD ID; // 11/29-bit message identifier
TPCANMessageType MSGTYPE; // Type of the message
BYTE DLC; // Data Length Code of the message (0..15)
BYTE DATA[64]; // Data of the message (DATA[0]..DATA[63])
} TPCANMsgFD;
BYTE LEN; // Data Length Code of the message (0..8)
BYTE DATA[8]; // Data of the message (DATA[0]..DATA[7])
} TPCANMsg;
int GetLengthFromDLC(BYTE dlc)
switch (dlc)
case 9: return 12;
case 10: return 16;
case 11: return 20;
case 12: return 24;
case 13: return 32;
case 14: return 48;
case 15: return 64;
default: return dlc;
Perfect. Thanks the team
