Maximum SER_RX_FIFO_SIZE
Programmable Converter for RS-232 to CAN
damenc
Post by damenc » Thu 5. May 2022, 07:48
In the example programs, the size of SER_RX_FIFO_SIZE is dfined as 250:
#define	SER_RX_FIFO_SIZE		250
// RX Fifo (soft-fifo write by RX complete interrupt)
static u8_t  RxFifo[SER_RX_FIFO_SIZE];
What is the maximum supported size for SER_RX_FIFO_SIZE?
Re: Maximum SER_RX_FIFO_SIZE
Post by PEAK-Support » Thu 5. May 2022, 10:12
The MAX Value for the #define SER_TX_FIFO_SIZE and SER_RX_FIFO_SIZE is 255
See Struct of the SERInit_t
//! @name structures
//! structures for serial interaction
//! @brief
//! structure for serial initialization
typedef struct {
	u32_t		prescaler;			//!< prescaler value for serial port
	void		*pTxFifo;			//!< pointer for TX buffer
	void		*pRxFifo;			//!< pointer for RX buffer
	u8_t		databits;			//!< number of databits ( 5..8)
	u8_t		stopbits;			//!< number of stopbits ( 1..2)
	u8_t		parity;				//!< mode of parity ( see SER_PARITY_..)
	u8_t		TxFifoSize;			//!< size of TX buffer space
	u8_t		RxFifoSize;			//!< size of RX buffer space
	u8_t		ISRnum;				//!< number of VIC channel for ISR routine
} SERInit_t;
If you need a larger Queue build your own in front of the Queue of the LIB.
damenc
Post by damenc » Fri 20. May 2022, 09:30
Thank you!
