Flashjing PCAN return a wrong status Hardware
Universal Programmable Converter for CAN FD and CAN
remi.deparis@stellantis.com
Post by remi.deparis@stellantis.com » Tue 28. Jun 2022, 13:25
hello
during flash PCAN-ROUTER FD an error code is returning at begining of flash process
Error : The CAN Hardware send a wrong statuds Code
but example Code 001-ROUTING is well flahing
compare to example I added C/C++ optimisation :
CFLAGS += -Wall -Wcast-align -Wcast-qual -flto -ffat-lto-objects -fmerge-constants
CFLAGS += -Wpointer-arith -Wswitch
CFLAG += -ffunction-sections -fdata-sections
CFLAGS += -Wreturn-type -Wshadow -Wunused
thanks for your help
BR
see one C++ compilation
Compiling C++: ./RESSOURCES_MBED/Sources/SauvegardeVersionsSoft.cpp
arm-none-eabi-g++  -c -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -I. -gdwarf-2 -DMODEFUNC -DEVENT -DBENCH -DPCAN_ROUTER_FD=1 -DRUNTIME_TYPEARCHIEE -DAEE2020 -DGCC=1 -D__USE_CMSIS -DARMCM4_FP  -Os -Wall -Wcast-align -Wcast-qual -flto -ffat-lto-objects -fmerge-constants -Wpointer-arith -Wswitch -Wreturn-type -Wshadow -Wunused -Wa,-adhlns=./lst/SauvegardeVersionsSoft.lst -I./pcan/inc -I./Lgp/Includes -I./Applicatif/Includes -I./RESSOURCES_MBED/Includes -I./Applicatif/Messagerie -I./Applicatif/Messagerie/COMMON -I./Applicatif/Messagerie/ENUM -I./Applicatif/Messagerie/CONF -I./Applicatif/Messagerie/ECRAN -I./Applicatif/Messagerie/ECRAN_HS3 -I./Applicatif/Messagerie/ECRAN_ID -I./Applicatif/Messagerie/ECRAN_HS7 -I./Applicatif/Messagerie/GENERIC -I./Applicatif/Messagerie/HS3 -I./Applicatif/Messagerie/HAB -I./Applicatif/Messagerie/HS7 -I./Applicatif/Messagerie/H7R -I./Applicatif/Messagerie/FD7 -I./Applicatif/Messagerie/HS3_ID -I./Applicatif/Messagerie/HAB_HS7 -I./Applicatif/Messagerie/HS7_ID -I./Applicatif/Messagerie/HS7_HAB -I./Applicatif/Messagerie/HS7_H7R -I./Applicatif/Messagerie/ID -I./Applicatif/Messagerie/IS -MD -MP -MF ./dep/SauvegardeVersionsSoft.o.d -DMODEFUNC -DEVENT -DBENCH -DPCAN_ROUTER_FD=1 -DRUNTIME_TYPEARCHIEE -DAEE2020  -ffunction-sections -fdata-sections ./RESSOURCES_MBED/Sources/SauvegardeVersionsSoft.cpp -o obj/SauvegardeVersionsSoft.o
see linker
Linking: PCANBench.elf
arm-none-eabi-gcc  -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -I. -gdwarf-2 -DMODEFUNC -DEVENT -DBENCH -DPCAN_ROUTER_FD=1 -DRUNTIME_TYPEARCHIEE -DAEE2020 -DGCC=1 -D__USE_CMSIS -DARMCM4_FP  -Os -Wall -Wcs
-Wunused -Wa,-adhlns=./lst/PCANBench.lst -I./pcan/inc -I./Lgp/Includes -I./Applicatif/Includes -I./RESSOURCES_MBED/Includes -I./Applicatif/Messagerie -I./Applicatif/Messagerie/COMMON -I./Applicatif/Messagerie/ENUM -I./Applicatif/Messagerie/CONF -I./Applicatif/Messagerie/ECRAN -I./Applicatif/Messagerie/ECRAN_HS3 -I./Applicatif/Messagerie/ECRAN_ID -I./Applicatif/Messagerie/ECRAN_HS7 -I./Applicatif/Messagerie/GENERIC -I./Applicatif/Messagerie/HS3 -I./Applicatif/Messagerie/HAB -I./Applicatif/Messagerie/HS7 -I./Applicatif/Messagerie/H7R -I./Applicatif/Messagerie/FD7 -I./Applicatif/Messagerie/HS3_ID -I./Applicatif/Messagerie/HAB_HS7 -I./Applicatif/Messagerie/HS7_ID -I./Applicatif/Messagerie/HS7_HAB -I./Applicatif/Messagerie/HS7_H7R -I./Applicatif/Messagerie/ID -I./Applicatif/Messagerie/IS -MD -MP -MF ./dep/PCANBench.elf.d  ./obj/startup_ARMCM4.o ./obj/system_LPC407x_8x_177x_8x.o ./obj/can_user.o ./obj/ser_user.o ./obj/ID_HS3_TransposeHelper.o ./obj/HS3_ID_TransposeHelper.o ./obj/H7R_ECRAN_TransposeHelper.o ./obj/ECRAN_H7R_TransposeHelper.o ./obj/HAB_HS7_TransposeHelper.o ./obj/HS7_HAB_TransposeHelper.o ./obj/H7R_MessagerieHelper.o ./obj/H7R_Messagerie.o ./obj/H7R_MessageriePeriodTrame.o ./obj/H7R_Encode.o ./obj/H7R_Decode.o ./obj/HS7_ID_TransposeHelper.o ./obj/ID_HS7_TransposeHelper.o ./obj/HS3_MessagerieHelper.o ./obj/HS3_Messagerie.o ./obj/HS3_MessageriePeriodTrame.o ./obj/HS3_Decode.o ./obj/HS3_Encode.o ./obj/FD7_Messagerie.o ./obj/FD7_MessagerieHelper.o ./obj/FD7_MessageriePeriodTrame.o ./obj/FD7_Decode.o ./obj/FD7_Encode.o ./obj/IS_Decode.o ./obj/IS_Encode.o ./obj/IS_MessagerieHelper.o ./obj/IS_MessageriePeriodTrame.o ./obj/IS_Messagerie.o ./obj/ECRAN_MessageriePeriodTrame.o ./obj/ECRAN_Messagerie.o ./obj/ECRAN_Decode.o ./obj/ECRAN_MessagerieHelper.o ./obj/ECRAN_Encode.o ./obj/ECRAN_ID_TransposeHelper.o ./obj/ID_ECRAN_TransposeHelper.o ./obj/ECRAN_FD7_TransposeHelper.o ./obj/FD7_ECRAN_TransposeHelper.o ./obj/FD3_Messagerie.o ./obj/FD3_Encode.o ./obj/FD3_MessagerieHelper.o ./obj/FD3_Decode.o ./obj/FD3_MessageriePeriodTrame.o ./obj/Generic_Encode.o ./obj/GENERIC_Messagerie.o ./obj/CONF_Encode.o ./obj/CONF_MessagerieHelper.o ./obj/CONF_MessageriePeriodTrame.o ./obj/CONF_Messagerie.o ./obj/CONF_Decode.o ./obj/HS7_ECRAN_TransposeHelper.o ./obj/ECRAN_HS7_TransposeHelper.o ./obj/ID_Encode.o ./obj/ID_Decode.o ./obj/ID_Messagerie.o ./obj/ID_MessageriePeriodTrame.o ./obj/ID_MessagerieHelper.o ./obj/HAB_MessageriePeriodTrame.o ./obj/HAB_Messagerie.o ./obj/HAB_Encode.o ./obj/HAB_MessagerieHelper.o
./obj/HAB_Decode.o ./obj/ECRAN_HS3_TransposeHelper.o ./obj/H7R_HS7_TransposeHelper.o ./obj/HS7_H7R_TransposeHelper.o ./obj/HS7_Encode.o ./obj/HS7_Messagerie.o ./obj/HS7_Decode.o ./obj/HS7_MessageriePeriodTrame.o ./obj/HS7_MessagerieHelper.o ./obj/Messagerie_ValidationSysteme.o ./obj/appStructMessagerie.o ./obj/Messagerie_Ecran_MBED_HS7.o ./obj/Messagerie_HS7_MBED_H7R.o ./obj/Messagerie_Ecran_MBED_ID.o ./obj/Messagerie_Ecran_MBED_HS3.o ./obj/Messagerie_Ecran_MBED_H7R.o ./obj/ModeBancTestGSM.o ./obj/GestionLangue.o ./obj/main.o ./obj/HS3TrameEvent.o ./obj/GestionPanneauDrive.o ./obj/Interface_RessourcesHW_App.o ./obj/ModePasserelleCANCAN.o ./obj/GestionPanneauSettings.o ./obj/HS7TrameEvent.o ./obj/GestionPanneauVisioPark.o ./obj/GestionPanneauRoutineControl.o ./obj/VersionSoftApp.o ./obj/H7RTrameEvent.o ./obj/GestionConso.o ./obj/ParserFichierDateVIN.o ./obj/ModeSleep.o ./obj/Messagerie_Diagnostic.o ./obj/ConfigSettingsFactory.o ./obj/IDTrameEvent.o ./obj/GestionLifeCycle.o ./obj/GestionDate.o ./obj/GestionFonctionsActivesCdeLedPush.o ./obj/GestionPanneauClim.o ./obj/ModeMbedFactory.o
./obj/GestionVIN.o ./obj/AbstractSettingsFactory.o ./obj/FIFO.o ./obj/GestionEnvoiCan.o ./obj/FiltrageCAN.o ./obj/QEI.o ./obj/DriverLIN.o ./obj/VERSION_LGP.o ./obj/ReconstitutionSerialisation.o ./obj/SauvegardeVersionsSoft.o ./obj/RessourcesHardwareGeneriques.o ./pcan/lib/libPCAN-Router_FD_02.a --output ./out/PCANBench.elf -Wl,-Map=./out/PCANBench.map,--cref  -lm -lc -lgcc  -lstdc++ -N --specs=nosys.specs -Tpcan_router_fd.ld
Creating load file for Flash: PCANBench.hex
arm-none-eabi-objcopy -O ihex ./out/PCANBench.elf ./out/PCANBench.hex
Creating Extended Listing: PCANBench.lss
arm-none-eabi-objdump -h -S -C ./out/PCANBench.elf > ./out/PCANBench.lss
Creating Symbol Table: PCANBench.sym
arm-none-eabi-nm -n ./out/PCANBench.elf > ./out/PCANBench.sym
Creating bin file: PCANBench.bin
hex2bin -s 0000 ./out/PCANBench.hex
hex2bin v1.0.9, Copyright (C) 2012 Jacques Pelletier
checksum extensions Copyright (C) 2004 Rockwell Automation
improved P.G. 2007, modified Danny Schneider,2012
Lowest address  = 00005000
Highest address = 0001D28B
Pad Byte        = FF
8-bit Checksum = 2D
Size after:
./out/PCANBench.elf  :
section             size        addr
.text              95400       20480
.ARM.extab           308      115880
.ARM.exidx           704      116188
.copy.table           24      116892
.zero.table            8      116916
.data               2512   268435456
.data2                 0   536870912
.bss                2564   268437968
.bss2                  0   536870912
.heap                 12   268440532
.stack              1024   268499968
.ARM.attributes       48           0
.comment             126           0
.debug_info        35562           0
.debug_abbrev       2796           0
.debug_loc         18105           0
.debug_aranges       216           0
.debug_ranges       2168           0
.debug_line         6439           0
.debug_str         16159           0
.debug_frame       14876           0
.stab                204           0
.stabstr             441           0
Total             199696
Errors: none
-------- end --------
Le terminal sera réutilisé par les tâches, appuyez sur une touche pour le fermer.
2022-06-28 13_17_17-PEAK-System_error_hardware.png (92.96 KiB) Viewed 6705 times
Reason: Inserted [code] tags for improved readability of log excerpts.
Re: Flashjing PCAN return a wrong status Hardware
Post by PEAK-Support » Wed 29. Jun 2022, 09:25
If you change make file / code samples etc. we are not able to do any support without having the complete, ready to compile, project. Please use the CPP sample project as template if you want to use the CPP extension.
This sample ist tested and work fine!
..\Hardware\PCAN-Router_FD\Examples\14_CPLUSPLUS\
dominic_v
Post by dominic_v » Mon 30. Oct 2023, 16:54
I'm having the exact same problem. The logging software loads fine however.
My application was based on an example with the addition of some of my files.
Was the cause of this problem determined?
Post by M.Maidhof » Tue 31. Oct 2023, 12:32
please send the *.bin file which you try to flash to our support email address, as already answered to your support request by email.
Post by PEAK-Support » Tue 31. Oct 2023, 21:39
Topic closed - customer do not use the correct tools and create a invalid bin file, which could not be flashed…
