We want to try to use one of PCAN to complete the send and recive of ISOTP(API from PCAN-ISO-TP_2016.cs), so we called the following C# function, we can send the first message and recive the feedback message, but when we call the 2nd MsgDataInit_2016, it will be failed.
Could you help to point out the cause of the error or where it needs to be corrected? The following is our code flow.
Thx
// Initialize channels: CAN2.0 - 500Kbit/s
res = CanTpApi.Initialize_2016(transmitter_handle, cantp_baudrate.PCANTP_BAUDRATE_500K);
Console.WriteLine("Initialize transmitter : {0}", STATUS_OK_KO(res));
// Allocate tx CAN message
res = CanTpApi.MsgDataAlloc_2016(out tx_msg, cantp_msgtype.PCANTP_MSGTYPE_CAN);
Console.WriteLine("Allocate tx CAN message : {0}", STATUS_OK_KO(res));
// Allocate rx message
res = CanTpApi.MsgDataAlloc_2016(out rx_msg, cantp_msgtype.PCANTP_MSGTYPE_NONE);
Console.WriteLine("Allocate rx message : {0}", STATUS_OK_KO(res));
// Initialize Tx message containing "SartDownload"
uint can_id = 0x700;
byte[] dataSartDownload = { 0x81, 0x27, 0x72, 0xd7, 0x68, 0xfa, 0x81, 0xed };
res = CanTpApi.MsgDataInit_2016(out tx_msg, can_id, cantp_can_msgtype.PCANTP_CAN_MSGTYPE_EXTENDED, 8, dataSartDownload);
Console.WriteLine("Initialize tx message : {0}", STATUS_OK_KO(res));
// Write "dataSartDownload" message
res = CanTpApi.Write_2016(transmitter_handle, ref tx_msg);
Console.WriteLine("Write \"SartDownload\" message : {0}", STATUS_OK_KO(res));
// Free messages space
res = CanTpApi.MsgDataFree_2016(ref tx_msg);
Console.WriteLine("Free tx message : {0}", STATUS_OK_KO(res));
// Uninitialize channels
res = CanTpApi.Uninitialize_2016(transmitter_handle);
Console.WriteLine("Uninitialize transmitter : {0}", STATUS_OK_KO(res));
res = CanTpApi.Initialize_2016(receiver_handle, cantp_baudrate.PCANTP_BAUDRATE_500K);
Console.WriteLine("Initialize receiver : {0}", STATUS_OK_KO(res));
// Create and set a receive event on receiver
System.Threading.AutoResetEvent receive_event = new System.Threading.AutoResetEvent(false);
if (IntPtr.Size == 4)
UInt32 iBuffer = Convert.ToUInt32(receive_event.SafeWaitHandle.DangerousGetHandle().ToInt32());
res = CanTpApi.SetValue_2016(transmitter_handle, cantp_parameter.PCANTP_PARAMETER_RECEIVE_EVENT, ref iBuffer, sizeof(UInt32));
else if (IntPtr.Size == 8)
Int64 iBuffer = receive_event.SafeWaitHandle.DangerousGetHandle().ToInt64();
byte[] byteArray = BitConverter.GetBytes(iBuffer);
res = CanTpApi.SetValue_2016(receiver_handle, cantp_parameter.PCANTP_PARAMETER_RECEIVE_EVENT, byteArray, sizeof(UInt64));
Console.WriteLine("Set receive event on receiver : {0}", STATUS_OK_KO(res));
// Wait a receive event on receiver
bool wait_result = receive_event.WaitOne(100000);
Console.WriteLine("Wait a message on receiver : {0}", OK_KO(wait_result));
// If we receive something on the receiver, read the message
if (wait_result)
res = CanTpApi.Read_2016(receiver_handle, out rx_msg);
Console.WriteLine("Read message on receiver : {0}", ByteArrayToString(rx_msg.Msgdata_can_Copy.data_max));
String valSartDownload = "0000000000000000";
var rx_result = ByteArrayToString(rx_msg.Msgdata_can_Copy.data_max);
byte val = 0;
if (CanTpApi.getData_2016(ref rx_msg, 0, out val))
Console.WriteLine("Check if the message is \"SartDownload\" : {0}", OK_KO(ByteArrayToString(rx_msg.Msgdata_can_Copy.data_max) == valSartDownload));
else
Console.WriteLine("Check if the message is \"SartDownload\" : NOK");
res = CanTpApi.MsgDataFree_2016(ref rx_msg);
Console.WriteLine("Free rx message : {0}", STATUS_OK_KO(res));
res = CanTpApi.Uninitialize_2016(receiver_handle);
Console.WriteLine("Uninitialize receiver : {0}", STATUS_OK_KO(res));
---------// the 2nd MsgDataInit will fail-------------------------
// Write "dataSart2nd" message
