Sending variable value to excel
PMJ
Post by PMJ » Fri 11. Jan 2013, 09:46
I need send few variables to the columns a,b,c in excel.
I'm using vbs macro but don't have idea how to do it.
Can You help me?
Re: Sending variable value to excel
Post by PEAK-Support » Fri 11. Jan 2013, 11:21
Please tell us in detail what you want to do. We need more info about the PE4 Version you use (Version), do you work with signals (Symbol File) or raw CAN Messages etc. What exact is the target file format , what the input etc. Without more detailed information we could not help you - sorry...
PMJ
Post by PMJ » Fri 11. Jan 2013, 12:18
I have version 5.2.2.773 and using signals. I'm testing battery-pack , reading parameters when pack is discharge and calculate parameters. I won this reeded and calculated parameters write to standard excel xls file in column and line.If You need i can send macro file to You support mail.
Post by PEAK-Support » Fri 11. Jan 2013, 12:30
Yes, please send your Macro and the License Number of your PE5 to support[at]peak-system.com - we have made some samples that could be solve your problem (export signals to CSV)
