Importing trc file in Plotter
appalaraju
Post by appalaraju » Thu 24. Nov 2022, 07:40
** moved by ADMIN to the correct section **
When I import trc files from others in the Plotter, some times I get the error " No signals found". But, it works fine with other trc files.
What are the possible reasons for this ?
Re: Importing trc file in Plotter
Post by M.Maidhof » Thu 24. Nov 2022, 09:00
typical reasons are:
- no symbol file loaded
- symbol file loaded which does not match to the given data.
- busnumer of the connection does not fit to the busnumber used in the trace
Post by PEAK-Support » Thu 24. Nov 2022, 09:01
Looks like a missing Symbol File. Without the correct Symbol File, which include a to the Trace corresponding BUS Number (see connections) it will not work.
If you still haev problems, please contact us at support[at]peak-system.com and send us your used PE License (do not post here in the Forum!!)
