DBC import
Mobile diagnostic device for CAN and CAN FD buses with optional J1939 add-in
JayDeeTech
DBC import
Post by JayDeeTech » Fri 2. Dec 2022, 14:06
For the Diag FD do I have to covert DBC to PEAK symbol using the symbol editor?
Does the symbol editor require a liecenceto do this? Is this licence included with the PCAN-Diag FD.
regards, John.
Re: DBC import
Post by M.Maidhof » Fri 2. Dec 2022, 16:07
yes, you need a PCAN-Explorer 6 license with CAN_db Add-In to be able to import dbc files in the symbol editor.
JayDeeTech
Re: DBC import
Post by JayDeeTech » Fri 2. Dec 2022, 16:42
Ok, to confirm, to get the full use of the Diag FD you need the full Peak software tool chain and it should not be considered a stand alone product?
Regards, John.
Re: DBC import
Post by PEAK-Support » Fri 2. Dec 2022, 22:51
The Diag FD could not use CANdb Files, it use Symbol files. See product description.
The PCAN-Explorer (PC Software) have a additional option of import / export the file format from company VECTOR to our Symbol files.
The Diag-FD is a CAN Layer 1 Tool! Using it for decoding CAN layer 2 Data is a additional function, using our Symbol files.
So, no - no need of additional Software, It s a completely independent product. Simply use our format with our Editor for CAN decoding.
