Can PCAN-View acknowledge Can-Bus Messages?
blipton
Post by blipton » Sun 5. Feb 2023, 16:29
I have a device that transmits Can-Bus data, yet PCAN-View doesn't show the data, only "BUSHEAVY".
With the oscilloscope I see continuous traffic on the bus, so not sure if it's a bit-rate mismatch, or if there needs to be a node that acknowledges otherwise it will continue to send it. The smallest bitwidth that the scope shows is consistent with the bitrate set in PCAN-View.
Does the PEAK-USB device / PCAN-View acknowledge messages or only monitor? What else could cause BUSHEAVY?
Re: Can PCAN-View acknowledge Can-Bus Messages?
Post by M.Maidhof » Mon 6. Feb 2023, 09:53
by default PCAN-View set the acknowldge bit. Only if you set PCAN-View in Listen-Only mode, it will set no ack. But you should see messages in the receive window in both cases, if you have selected the correct bitrate settings.
