I'm correctly receiving data from the CAN interface of externally labeled "CAN2" which looks to be can_1 in the ini.
I cannot get this interface to send data on the CAN bus. I've tried both TCP and UDP. The Data I'm sending looks like this:
0x0024 0080 0000 0000 0000 0000 4C78 80F2 0000 0017 0008 0000 0000 0047 0807 0605 0403 0201
This is the same format of the received message, I just change the ID to 47 so there is not a collision.
[can_1]
if_name = Second CAN interface
active = 1
listen_only = 0
auto_resume = 1
loop_back = 0
one_shot = 0
triple_sampling = 0
br_def = 0
core_clock = 24000000
bit_rate = 500000
sample_point = 800
enable_error_counter = 0
measure_bus_load = 0
[rt_0]
rt_info = Try this
active = TRUE
type = LAN2CAN
interface_1 = can1
protocol_2 = UDP
destination_2 = 0.0.0.0:7777
fpp = 15
tcp_delay = TRUE
disp_idx = 0
snd_delay_us = 300
snd_max = 30
connect_delay_ms = 500
invert_socket_mode = FALSE
use_crc_frm = FALSE
crc_start_value = 0x00000000
crc_polynom = 0x04C11DB7
no_ctrl = FALSE
no_keep_alive = FALSE
unify_filters = FALSE
join_filters = FALSE
[rt_2]
rt_info =
active = TRUE
type = CAN2LAN
interface_1 = can1
protocol_2 = UDP
destination_2 = 192.168.1.138:9851
fpp = 1
tcp_delay = TRUE
disp_idx = 0
snd_delay_us = 300
snd_max = 30
use_crc_frm = FALSE
no_ctrl = FALSE
Can Receive CAN data but cannot send
Re: Can Receive CAN data but cannot send
handshake....
It works.
It works.
For all other users - here a more understandable answer for this "problem"
If you don't use our PC software Virtual-PCAN-Getway, but use your own socket based software, the handshake on the modules must be switched off.
This and many, many more useful information can be found in the developer documentation for the device.
