SimonH
Post
by SimonH » Thu 27. Jul 2023, 14:32
peak driver 8.16.0
PCAN-Basic_Linux 4.7.0.3
Hardware: PCAN USB IPEH-002022
Hey,
im currently learning to work with CAN Bus and wanted to try the CAN Write function provided in the PCAN Basic doc. While compiling I got the error message:
can_send_test.cpp:30:38: error: cannot convert ‘TPCANMsg’ {aka ‘tagTPCANMsg’} to ‘TPCANMsg*’ {aka ‘tagTPCANMsg*’}
30 | result = CAN_Write(PCAN_USBBUS1, msg);
I added my c++ code below, any help would be appreciated :)
#include<iostream>
#include<PCANBasic.h>
#include <asm/types.h>
#define DWORD __u32
#define WORD unsigned short
#define BYTE unsigned char
#define LPSTR char*
int main() {
TPCANMsg msg;
TPCANStatus result;
char strMsg[256];
// Konfigurieren einer CAN Nachricht
msg.ID = 895;
msg.MSGTYPE = PCAN_MESSAGE_STANDARD;
msg.LEN = 4;
msg.DATA[0] = 0xFF;
msg.DATA[1] = 0x00;
msg.DATA[2] = 0x00;
msg.DATA[3] = 0x00;
// Die Nachricht wird über den PCAN-USB Kanal-1 gesendet.
return 0;
K.Wagner on Thu 27. Jul 2023, 14:37, edited 1 time in total.
Reason: Code formatting for better reading
Post
by K.Wagner » Thu 27. Jul 2023, 14:43
You have the answer already in the compiler error. Please note that the parameter "
msg" has to be passed as a reference. Here the declaration of CAN_Write from PCANBasic.h:
/// <summary>
/// Transmits a CAN message
/// </summary>
/// <param name="Channel">"The handle of a PCAN Channel"</param>
/// <param name="MessageBuffer">"A TPCANMsg buffer with the message to be sent"</param>
/// <returns>"A TPCANStatus error code"</returns>
TPCANStatus __stdcall CAN_Write(
TPCANHandle Channel,
TPCANMsg* MessageBuffer);
So, the compiler message "error: cannot convert ‘
TPCANMsg*’ {aka ‘tagTPCANMsg*’}" is quite clear.
Post
by K.Wagner » Thu 27. Jul 2023, 14:49
An additional note:
if the code you posted is the whole code being used, then it will not work since you need to initialize the channel first (see CAN_Initialize). Please check the help files and try to understand the sample projects first, before startig an application from scratch.
