Unable to view the data on the PCAN-View
Pujari
Post by Pujari » Tue 10. Oct 2023, 11:08
I have modified the "02_client_ISO15765-2_normal_addressing" python example code to exercise the multi-packet data write. When i run the code without PCAN-View, both Tx & Rx Api's gives good response "OK".
I am initialization with below change
PCAN_BITRATE_SAE_J2284_4 = create_string_buffer(b'f_clock=80000000,nom_brp=2,nom_tseg1=63,nom_tseg2=16,nom_sjw=16,data_brp=2,data_tseg1=15,data_tseg2=4,data_sjw=4')
# Initialize channel: CAN2.0 - 500Kbit/s
res = objPCANIsotp.Initialize_2016(client_handle, PCAN_BITRATE_SAE_J2284_4)
print("Initialize: ", STATUS_OK_KO(res))
PCAN-ISO-TP API Version: b'3.5.0.344'
Initialize: OK
Set STMIN = 600us: OK
Allocate tx message: OK
Add a simple mapping: OK
Initialize tx message: OK
Write " PEAK-System - PCAN-ISO-TP Sample " message: OK
Initialize rx message xx: OK
CANTP_Read_2016 (indication): KO, netstatus=0b
Free rx message: OK
Initialize rx message: OK
CANTP_Read_2016 (complete): KO, netstatus=0b
Free rx message: OK
Free tx message: OK
Uninitialize: OK
Press <Enter> to close
But no data is captured on the PCAN-View.
Also with PCAN-View, if i run the "02_client_ISO15765-2_normal_addressing" python example code, the initialization doesn't go through.
Initialize: KO
Set STMIN = 600us: KO
Add a simple mapping: KO
CANTP_Read_2016 (indication): KO, netstatus=00
Free rx message: OK
CANTP_Read_2016 (complete): KO, netstatus=00
Free rx message: OK
Free tx message: OK
Uninitialize: KO
Can you please guide how to view the data on the PCAN-View.
Re: Unable to view the data on the PCAN-View
Post by K.Wagner » Tue 10. Oct 2023, 12:44
Please take care that PCAN-View and your applications are using exactly the same bit rate. Otherwise either:
  • PCAN-View will not be able to read anything (for example, PCAN-View receiving on channel 2 and you are sending from channel 1)
  • Or, your application will not be able to connect to that channel (for example, you have already a PCAN-View attached to channel 1, and you want to connect your app to channel 1 as well)
Pujari
Post by Pujari » Tue 10. Oct 2023, 12:57
Thanks for the reply.
To view the data on the PCAN-View, I need to use another PCAN-USB. Is my understanding correct.
Please confirm.
Anand Pujari
Post by K.Wagner » Tue 10. Oct 2023, 14:57
Dear,
please understand that:
  • You need at least two CAN nodes in a network in order to be able to see communication (basic CAN specifications)
  • You need to use exact the same bit rate configuration for all participants
  • You can attach a PCAN-View to a CAN node that is being used by one PCAN-ISO-TP application
  • You can attach a PCAN-ISO-TP application to a CAN node that is being used by a PCANV-View
  • Each PCAN channel (physical channel of a PCAN device) can be connected only by one PCAN-ISO-TP application at a time, and one or more PCAN-Views (or other PCAN applications, like PCAN-Explorer)
You need to use the PCAN-View as a second node of your "environment" or connect it to one of the nodes (at least two) that you need to have to be available to see communication.
