i am currently working on an application for development purposes. Therefore i got a quite unusual requirement on our can node.
Is it possible to receive CAN FD messages while sending CAN 2.0 messages on one channel via a PCAN-USB-FD (IPEH-004022) using the PCAN-Basic API ?
We noticed that the PCAN-View is capable of this. But only one of the protocols can be initialized and used via the API at the same time. Is there maybe a known workaround ?
Thanks !
Using CAN FD and CAN 2.0 at the same time
Re: Using CAN FD and CAN 2.0 at the same time
Yes, no Problem. When you call CAN-Write(...) you send a CAN Message Structure to the driver.
Simply do NOT set in the MsgType the BRS (Bit Rate Switch) Bit and do not SET the CAN-FD Bit.
Also keep the DLC to max. 8 . Then it is a 100% compatible CAN2.0a/b Frame.
Thank you very much for your quick response.
Worked
Worked
** problem solved - Topic closed **
