CANID MAPPING
Ken0711
CANID MAPPING
Post by Ken0711 » Thu 24. Aug 2023, 05:34
Hi Peak Support,
PCAN-UDS API Version-2.3.0.256
When I used UDSApi.AddMapping_2013 function to mapping CANID(request 0X784,Response 0x 78C) and used the sample (UDS specification page 166 with C# )
and then send the uds diagnostic session control message with function UDSApi.SvcDiagnosticSessionControl_2013(sample from page260)
and after running the code ,initialization and mapping seems successful ,but arose error(PUDS_STATUS_SERVICE_TX_ERROR) when sent the diagnostic session message
Below is my code
        private void Init_Click(object sender, EventArgs e)
            StringBuilder buffer = new StringBuilder(BUFFER_SIZE);
            stsResult = UDSApi.GetValue_2013(cantp_handle.PCANTP_HANDLE_NONEBUS, uds_parameter.PUDS_PARAMETER_API_VERSION, buffer, BUFFER_SIZE);
            MessageBox.Show("PCAN-UDS API Version - " + buffer.ToString());
            stsResult = UDSApi.Initialize_2013(m_clientHandle, m_baudrate, (cantp_hwtype)0, 0, 0);
            if(!UDSApi.StatusIsOk_2013(stsResult))
                MessageBox.Show(UDS_STATUS_OK_KO(stsResult));
            PUDS_SetRequestResponse_CANID();
        private void ReadMsg_Click(object sender, EventArgs e)
            //Thread uds_client = new Thread(() => uds_client_task());
            //uds_client.Start();
            UDS_BOOT_Process1();
        public void PUDS_SetRequestResponse_CANID()
            UInt16 mapping_count;
            uds_mapping[] mapping_buffer = new uds_mapping[BUFFER_SIZE];
            uds_mapping request_mapping = new uds_mapping();
            request_mapping.can_id = 0x784;
            request_mapping.can_id_flow_ctrl = 0x78C;
            request_mapping.can_msgtype = cantp_can_msgtype.PCANTP_CAN_MSGTYPE_STANDARD;
            request_mapping.nai.extension_addr = 0;
            request_mapping.nai.protocol = uds_msgprotocol.PUDS_MSGPROTOCOL_ISO_15765_2_11B_NORMAL;
            request_mapping.can_tx_dlc = 8;
            request_mapping.nai.source_addr =(UInt16)uds_address.PUDS_ADDRESS_ISO_15765_4_ADDR_TEST_EQUIPMENT;
            request_mapping.nai.target_addr = (UInt16)uds_address.PUDS_ADDRESS_ISO_15765_4_ADDR_ECU_1;
            request_mapping.nai.target_type = cantp_isotp_addressing.PCANTP_ISOTP_ADDRESSING_PHYSICAL;
            uds_mapping response_mapping;
            response_mapping = request_mapping;
            response_mapping.can_id = request_mapping.can_id_flow_ctrl;
            response_mapping.can_id_flow_ctrl = request_mapping.can_id;
            response_mapping.nai.source_addr = request_mapping.nai.target_addr;
            response_mapping.nai.target_addr = request_mapping.nai.source_addr;
            mapping_count = 0;
            uds_status status;
            status = UDSApi.AddMapping_2013(m_clientHandle, ref request_mapping);
            if (UDSApi.StatusIsOk_2013(status))
                MessageBox.Show("Add request mapping", "Success");
            else
                MessageBox.Show("Failed to add request mapping", "Error");
            status = UDSApi.AddMapping_2013(cantp_handle.PCANTP_HANDLE_USBBUS1, ref response_mapping);
                MessageBox.Show("Add response mapping", "Success");
            else
                MessageBox.Show("Failed to add response mapping", "Error");
            status = UDSApi.GetMappings_2013(m_clientHandle, mapping_buffer, (UInt16)BUFFER_SIZE, ref mapping_count);
            bool mapp_sur= mapping_list_contains(ref mapping_buffer, mapping_count, ref request_mapping);
            bool mapp_res= mapping_list_contains(ref mapping_buffer, mapping_count, ref response_mapping);
        private void UDS_BOOT_Process1()
            uds_status result;
            uds_msg request = new uds_msg();
            uds_msg request_confirmation = new uds_msg();
            uds_msg response = new uds_msg();
            uds_msgconfig config = new uds_msgconfig();
            // Set request message configuration
            config.can_msgtype = cantp_can_msgtype.PCANTP_CAN_MSGTYPE_STANDARD;
            config.nai.extension_addr = 0x0;
            config.nai.protocol = uds_msgprotocol.PUDS_MSGPROTOCOL_ISO_15765_2_11B_NORMAL;
            config.nai.source_addr = (UInt16)uds_address.PUDS_ADDRESS_ISO_15765_4_ADDR_TEST_EQUIPMENT;
            config.nai.target_addr = (UInt16)uds_address.PUDS_ADDRESS_ISO_15765_4_ADDR_ECU_1;
            config.nai.target_type = cantp_isotp_addressing.PCANTP_ISOTP_ADDRESSING_PHYSICAL;
            //config.type = uds_msgtype.PUDS_MSGTYPE_USDT;
            // Sends a physical DiagnosticSessionControl message
            result = UDSApi.SvcDiagnosticSessionControl_2013(m_clientHandle, config,
            out request, UDSApi.uds_svc_param_dsc.PUDS_SVC_PARAM_DSC_ECUPS);
            if (UDSApi.StatusIsOk_2013(result))
                result = UDSApi.WaitForService_2013(cantp_handle.PCANTP_HANDLE_USBBUS1, ref request, out
                response, out request_confirmation);
                MessageBox.Show("Response was received", "Success");
            else
                // An error occurred
                MessageBox.Show("An error occurred", "Error");
            // Free structures
            UDSApi.MsgFree_2013(ref request);
            UDSApi.MsgFree_2013(ref response);
            UDSApi.MsgFree_2013(ref request_confirmation);
        static bool mapping_list_contains(ref uds_mapping[] mapping_list, UInt16 mapping_list_size, ref uds_mapping searched_mapping)
            bool res = false;
            for (int i = 0; i < mapping_list_size; i++)
                // If unique identifier are the same, the mapping is in the list
                if (mapping_list[i].uid == searched_mapping.uid)
                    res = true;
                    break;
            return res;
so what's the problem caused the error ?
thanks !
Reason: Code formatting for better reading
Re: CANID MAPPING
Post by K.Wagner » Thu 24. Aug 2023, 09:59
your code seems to be OK. Just be careful, that within the function PUDS_SetRequestResponse_CANID you are using a fix channel value in the second call to AddMapping_2013:
            else
Probably the problem is that are not receiving any response. The service timeouts because of this and you get a TX error. Please make sure yourself, that the ECU is configured to listend and response using the CAN-IDs you are confiuring. If you are emulating an ECU, for instance, using the sample 05_server_simulator, you need to configurate the mappings for it too, otherwise all messages will be ignored.
Ken0711
Re: CANID MAPPING
Post by Ken0711 » Mon 13. Nov 2023, 13:20
Hello ,PCAN Support,
About the CANID Mapping ,i met a new issue, when i used the differented CANID ,and Like this CANID( 784,78C),the MAPPING is Ok,udsstatus feedback PUDS_ERROR_OK
            TPUDSStatus result;
            TPUDSMsg mMessage = new TPUDSMsg();
            int mMessageSize;
            IntPtr mMessagePtr;
            mMessage.NETADDRINFO.SA= (byte)TPUDSAddress.PUDS_ISO_15765_4_ADDR_TEST_EQUIPMENT;
            mMessage.NETADDRINFO.TA = (byte)TPUDSAddress.PUDS_ISO_15765_4_ADDR_ECU_1;
            mMessage.NETADDRINFO.TA_TYPE = TPUDSAddressingType.PUDS_ADDRESSING_PHYSICAL;
            mMessage.NETADDRINFO.RA = 0x00;
            mMessage.NETADDRINFO.PROTOCOL = TPUDSProtocol.PUDS_PROTOCOL_ISO_15765_2_11B;
            mMessage.LEN = 8;
            mMessage.DATA = new byte[4095];
             mMessage.DATA[0] = (byte)((0x784 >> 24) & 0xFF);
            mMessage.DATA[1] = (byte)((0x784 >> 16) & 0xFF);
            mMessage.DATA[2] = (byte)((0x784 >> 8) & 0xFF);
            mMessage.DATA[3] = (byte)((0x784) & 0xFF);
            mMessage.DATA[4] = (byte)((0x78C >> 24) & 0xFF);
            mMessage.DATA[5] = (byte)((0x78C >> 16) & 0xFF);
            mMessage.DATA[6] = (byte)((0x78C >> 8) & 0xFF);
            mMessage.DATA[7] = (byte)((0x78C) & 0xFF);
            mMessageSize = Marshal.SizeOf(mMessage);
            mMessagePtr = Marshal.AllocHGlobal(mMessageSize);
            Marshal.StructureToPtr(mMessage, mMessagePtr, false);
            result = UDSApi.SetValue(UDSApi.PUDS_USBBUS1, TPUDSParameter.PUDS_PARAM_MAPPING_ADD, mMessagePtr, (uint)mMessageSize);
            Marshal.FreeHGlobal(mMessagePtr);
            if (result != TPUDSStatus.PUDS_ERROR_OK)
                return false;
            else
                return true;
But when i mapped with the CANID(7E4,7EC),it would be mapping failure(PUDS_ERROR_ALREADY_INITIALIZED)
   	   mMessage.DATA[0] = (byte)((0x7E4 >> 24) & 0xFF);
            mMessage.DATA[1] = (byte)((0x7E4 >> 16) & 0xFF);
            mMessage.DATA[2] = (byte)((0x7E4 >> 8) & 0xFF);
            mMessage.DATA[3] = (byte)((0x7E4) & 0xFF);
            mMessage.DATA[4] = (byte)((0x7EC >> 24) & 0xFF);
            mMessage.DATA[5] = (byte)((0x7EC >> 16) & 0xFF);
            mMessage.DATA[6] = (byte)((0x7EC >> 8) & 0xFF);
            mMessage.DATA[7] = (byte)((0x7EC) & 0xFF);
I used the same code just different CANID ,what's the problem ?
please check!
Thanks!
Reason: Text formatted for better reading
F.Vergnaud
Re: CANID MAPPING
Post by F.Vergnaud » Mon 13. Nov 2023, 14:00
You can't use the same network address information on different CAN IDs: it would mean there are several ways to communicate with the same ECU but the API has no way to identify how to select which one.
In your case you should change change the Target Address (mMessage.NETADDRINFO.TA).
Please also note that 0x7E4/0x7EC is a legislated OBD pair of CAN ID to communicate with ECU #5 (PUDS_ISO_15765_4_ADDR_ECU_5), these CAN IDs are defined in the API as:
- PUDS_ISO_15765_4_CAN_ID_PHYSICAL_REQUEST_5
- and PUDS_ISO_15765_4_CAN_ID_PHYSICAL_RESP0NSE_5.
This mapping is configured by default by the API, see chapter 4.3 "UDS and ISO-TP Network Addressing Information" in the UDS documentation.
Ken0711
Re: CANID MAPPING
Post by Ken0711 » Tue 14. Nov 2023, 04:42
Hi Vergnaud,
Thanks your feedback !
i tried your advise and checked it ,it also was PUDS_ERROR_ALREADY_INITIALIZED
and i also read the document ,4.3
below is my code !please check !
  static void Main(string[] args)
            if (InitUDS_Device() == true)
                PUDS_SetRequest_CANID();
                PUDS_SetResponse_CANID();
        bool InitUDS_Device()
            TPUDSStatus result_uds;
            try
                result_uds = UDSApi.Initialize(UDSApi.PUDS_USBBUS1, TPUDSBaudrate.PUDS_BAUD_500K);
                if (TPUDSStatus.PUDS_ERROR_OK != result_uds)
                    return false;
            catch
                return false;
            return true;
        bool PUDS_SetRequest_CANID()
            TPUDSStatus result;
            int mMessageSize;
            IntPtr mMessagePtr;
            mMessage.NETADDRINFO.SA = (byte)TPUDSAddress.PUDS_ISO_15765_4_ADDR_TEST_EQUIPMENT;
            mMessage.NETADDRINFO.TA = (byte)TPUDSAddress.PUDS_ISO_15765_4_ADDR_ECU_5;
            mMessage.LEN = 8;
                return false;
            else
                return true;
        bool PUDS_SetResponse_CANID()
            TPUDSStatus result;
            int mMessgeSize;
            IntPtr mMessagePtr;
            mMessage.NETADDRINFO.SA = (byte)TPUDSAddress.PUDS_ISO_15765_4_ADDR_ECU_5;
            mMessage.NETADDRINFO.TA = (byte)TPUDSAddress.PUDS_ISO_15765_4_ADDR_TEST_EQUIPMENT;
            //mMessage.NETADDRINFO.TA = (byte)0x09;
            mMessage.LEN = 8;
            mMessage.DATA[0] = (byte)((0x7E8 >> 24) & 0xFF);
            mMessage.DATA[1] = (byte)((0x7E8 >> 16) & 0xFF);
            mMessage.DATA[2] = (byte)((0x7E8 >> 8) & 0xFF);
            mMessage.DATA[3] = (byte)((0x7E8) & 0xFF);
            mMessgeSize = Marshal.SizeOf(mMessage);
            mMessagePtr = Marshal.AllocHGlobal(mMessgeSize);
            result = UDSApi.SetValue(UDSApi.PUDS_USBBUS1, TPUDSParameter.PUDS_PARAM_MAPPING_ADD, mMessagePtr, (uint)mMessgeSize);
                return false;
            else
                return true;
thanks!
F.Vergnaud
Re: CANID MAPPING
Post by F.Vergnaud » Tue 14. Nov 2023, 09:42
As mentioned previously the mapping 0x7E4/0x7EC is already configured by default by the API, this is why you get status PUDS_ERROR_ALREADY_INITIALIZED.
You can start sending UDS request with the corresponding NETADDRINFO.
Please note, you are using the old C# header "PCAN-UDS_2006.cs", it is strongly advised for new projects to use PCAN-UDS_2013.cs.
For instance, in your case you would get a more precise status: PUDS_STATUS_MAPPING_ALREADY_INITIALIZED.
Ken0711
Re: CANID MAPPING
Post by Ken0711 » Tue 14. Nov 2023, 10:01
Good morning Vergnaud
This measn it was not necessary to mapping the canid again ,and i can directly used it to send the UDS service ?
PUDS_ISO_15765_4_CAN_ID_PHYSICAL_RESPONSE_5 = 0x7EC,
/// <summary>
/// physical request CAN ID from external test equipment to ECU #6
/// </summary>
PUDS_ISO_15765_4_CAN_ID_PHYSICAL_REQUEST_6 = 0x7E5
as below this is not necessary
thanks!
F.Vergnaud
Re: CANID MAPPING
Post by F.Vergnaud » Tue 14. Nov 2023, 10:08
Yes: do not add the mapping it is already added when the channel is initialized. You can for instance service ECUReset like so:
            TPUDSStatus result_uds = UDSApi.SvcECUReset(UDSApi.PUDS_USBBUS1, ref mMessage, UDSApi.TPUDSSvcParamER.PUDS_SVC_PARAM_ER_HR);
Ken0711
Re: CANID MAPPING
Post by Ken0711 » Tue 14. Nov 2023, 10:59
Hi,Vergnaud
Thanks For your support !
I got it and solved it !
you can close tht topic !
Thanks again!
