Ubuntu 20.04 LTS (kernel 5.13.0-30-generic): "Unable to automatically find the Kernel headers"
stephen
Post by stephen » Wed 24. Jan 2024, 06:55
We have project in Japan and we use PCAN-USB on our hardware
OS: Ubuntu 20.04 LTS, Kernel 5.13.0-30-generic
We try to install PCAN-USB driver for two hardware
- Tiger Lake (i5-1145G7E) - OK
- Alder Lake (i7-1255U) - Fail
The SOP we did is below:
[1] download peak-linux-driver-8.15.2.tar.gz, and unzip it
[2] install g++ and libpopt-dev
$ sudo apt-get install build-essential g++
$ sudo apt-get install libpopt-dev
[3] Regarding the directory of peak-linux-driver-8.15.2
$ make clean
$ make
$ [sudo] make -C driver install
$ [sudo] make -C lib install
$ [sudo] make -C test install
$ [sudo] make -C libpcanbasic install
[4] After installation
$ wget -q https://urldefense.com/v3/__http://www. ... Uz0L5CshEA$ -O- | sudo tee /etc/apt/sources.list.d/peak-system.list
$ wget -q https://urldefense.com/v3/__http://www. ... Uz1I9QS3eA$ -O- | sudo apt-key add -
$ sudo apt-get update
$ sudo apt-get install pcanview-ncurses
[5] We disable secure boot and restart the system
$ sudo modprobe pcan
We install the PCAN-USB into our PC and type pcanview, and start the system
We are unable to install driver in i7-1255U and the error message shown below:
make [1]: directory '/hom/ubuntu/peak-linux-driver-8.15.2/driver' に入ります
Makefile:131: *** "Unable to automatically find the Kernel headers. There are mandatory to build the pcan dirver. Please set the KERNEL_LOCATION variable to the root directory of your own built Kernel.". Stop
make [1]: directory '/hom/ubuntu/peak-linux-driver-8.15.2/driver' から出ます
make: *** [Makefile:84: all] Error 2
We try to install new driver 8.16.0 and the one you released on 2024/1/18 v8.17, but we failed to install on the new intel platform Alder Lake i7-1255U
the error message always show after we type SOP [3] $ make clean
is there anything we can do for SOP? we are able to install drivers on intel old platform tiger lake but failed to install drivers on intel i7-1255U, we hope you can give us some advices, thanks and regards,
Stephen
Re: Ubuntu 20.04 LTS (kernel 5.13.0-30-generic): "Unable to automatically find the Kernel headers"
Post by M.Maidhof » Wed 24. Jan 2024, 09:50
the error is displayed. The kernel headers are missing. Please update the system, reboot once and try again, please also use latest driver 8.17:
sudo apt update
sudo apt upgrade
sudo reboot
If the kernel headers are still missing, post the output of "uname -a" to see which kernel is used on your system.
stephen
Post by stephen » Tue 30. Jan 2024, 11:39
Hi, Michael
We tried update, upgrade and reboot, but we are not able to use latest driver 8.17
The kernel is 5.19.17-05917-generic
regards,
Stephen
Post by M.Maidhof » Tue 30. Jan 2024, 13:17
please post the output of the driver make process. Did you install the kernel headers?
stephen
Post by stephen » Wed 31. Jan 2024, 11:12
Dear Michael:
Can you tell us how to build a Kernel headers? We tried old intel platform, we can install drivers without this issue. So we are not sure how to build a kernel headers.
We upgrate and upgrade and reboot, and this is the version information below, and the error message, please kindly check below:
Version information:
Linux ubuntu-QBiX-Pro-ADLA1255H 5.19.17-051917-generic
linux-generic-hwe-20.04 linux-headers-generic-hwe-20.04
linux-image-generic-hwe-20.04
g++ Version 4:9.3.0-1ubuntu2
build-essential Version 12.8ubuntu1.1
libpopt-dev Version 1.16-14
Error Message:
root@ubuntu-QBiX-Pro-ADLA1255H:~# cd /home/ubuntu/sugino/peak-linux-driver-8.17.0
root@ubuntu-QBiX-Pro-ADLA1255H:/home/ubuntu/sugino/peak-linux-driver-8.17.0# make clean
make[1]: ディレクトリ '/home/ubuntu/sugino/peak-linux-driver-8.17.0/driver' に入ります
Makefile:131: *** "Unable to automatically find the Kernel headers. These are mandatory to build the pcan driver. Please set the KERNEL_LOCATION variable to the root directory of your own built Kernel.". 中止.
make[1]: ディレクトリ '/home/ubuntu/sugino/peak-linux-driver-8.17.0/driver' から出ます
make: *** [Makefile:95: clean] エラー 2
make: *** [Makefile:84: all] エラー 2
S.Grosjean
Post by S.Grosjean » Wed 31. Jan 2024, 14:59
First, it's generally not a good idea to build the driver as root because PATH may be different.
Secondly, please give us the output of:
$ dpkg --get-selections "linux-headers*"
So that we'll definitively know if linux headers package is or isn't installed.
— Stéphane
stephen
Post by stephen » Mon 5. Feb 2024, 03:48
Dears:
We tested and the result is below:
ubuntu@ubuntu-QBiX-Pro-ADLA1255H:~$ sudo -i
[sudo] ubuntu のパスワード:
root@ubuntu-QBiX-Pro-ADLA1255H:~# dpkg --get-selections "linux-headers*"
linux-headers-5.11.0-27-generic install
linux-headers-5.15.0-91-generic install
linux-headers-5.15.0-92-generic install
linux-headers-5.15.0-94-generic install
linux-headers-5.19.17-051917 install
linux-headers-generic-hwe-20.04 install
Thanks and regards,
Stephen
S.Grosjean
Post by S.Grosjean » Mon 5. Feb 2024, 11:48
Therefore the Makefile is looking for linux headers of 5.19.17-05917-generic, which are generally installed when installing "linux-headers-5.19.17-05917-generic"...
... which is not installed according to:
On the other hand, if you know where the headers of your hand-made kernel are stored, then as indicated, use the KERNEL_LOCATION variable on the make command line, something like:
$ cd driver
$ make KERNEL_LOCATION=/usr/src/...
— Stéphane
stephen
Post by stephen » Mon 19. Feb 2024, 07:30
Do you mean 5.19.17-05917-generic is our kernel version, but what we install is linux-headers-5.19.17-051917 so it cause makefile failed?
Should we reinstall again?
I asked our client to try
$ cd driver
the results shown below:
ubuntu@ubuntu-QBiX-Pro-ADLA1255H:~$ cd driver
bash: cd: driver: そのようなファイルやディレクトリはありません
ubuntu@ubuntu-QBiX-Pro-ADLA1255H:~$ cd /home/ubuntu/sugino/peak-linux-driver-8.17.0/driver
ubuntu@ubuntu-QBiX-Pro-ADLA1255H:~/sugino/peak-linux-driver-8.17.0/driver$ make KERNEL_LOCATION=/usr/src/
*** Host OS Release=Ubuntu v20.04
*** Host machine kernel version=5.19.17-051917-generic
*** Driver kernel version=5.19.17-051917-generic (5.19.17)
*** Path to kernel sources=/usr/src/
*** use KBUILD=yes
*** use DKMS=
*** gcc version=9
/bin/sh: 1: cannot create dkms.conf: Permission denied
make: *** [Makefile:587: dkms.conf] エラー 2
Stephen
S.Grosjean
Post by S.Grosjean » Tue 20. Feb 2024, 09:51
When I wrote:
$ cd driver
"/usr/src/..." was an example, a template to put the actual directory of linux headers installed on your machine. I suppose that, in your case, you should write:
$ cd driver
$ make KERNEL_LOCATION=/usr/src/linux-headers-5.19.17-05917-generic
even though your installation seems quite strange to me: you're running a 5.19.17-051917-generic kernel:
"*** Host machine kernel version=5.19.17-051917-generic"
so you should have installed the "linux-headers-5.19.17-051917-generic" package, but that's obviously not the case, as it doesn't appear in the list you gave me:
— Stéphane
