Macros and UI
scope
Macros and UI
Post by scope » Wed 7. Feb 2024, 10:25
is there a way to map a button to run a Macro ?
Re: Macros and UI
Post by M.Maidhof » Wed 7. Feb 2024, 12:01
yes, simply put the name of the macro in the “Execute Command” property of the button. But note: this will only work when no other macro is working in that time and the macro is already available in the macro list.
dmeir
Re: Macros and UI
Post by dmeir » Mon 2. Sep 2024, 12:54
I cannot get my VBS macro to run this way.
The macro is loaded in the Project Manager, and no other macro (that I know of) is currently running.
I also can't add the macro to the "macro list" because it says "this macro is already loaded".
In the “Execute Command” property of my button I put the macro's filename without extension, as shown in the Project Manager's "Macros" list.
Bonus question: how do I only run a specific function out of a VBS macro file?
Re: Macros and UI
Post by M.Heidemann » Mon 2. Sep 2024, 13:53
You enter the name of a subroutine, not the Macro-File.
For example:
Sub doSomething()
PrintToOutputWindow "Hello!"
End Sub
in the execute Command property you just enter the name of the subroutine:
doSomething
(Notice: No Parenthesis, no Quotes).
Try again and let us know if it works now.
BR
dmeir
Re: Macros and UI
Post by dmeir » Thu 5. Sep 2024, 12:08
Thanks, this works.
I'll add that one has to use the complete name of the function including underscores (somewhere in the forum or documentation it was suggested that one has to remove the underscores).
