Receive Signal
Locked
scope
Receive Signal
Post by scope » Mon 12. Feb 2024, 10:32
In VBS Macro file how to use onReceive signal?
I've read the documentation but I can't get it to work
Re: Receive Signal
Post by M.Maidhof » Mon 12. Feb 2024, 10:45
please post your code to see what you are trying to do.
scope
Re: Receive Signal
Post by scope » Mon 12. Feb 2024, 10:53
** Forum Admin **
The own code is removed - because it is nearly a 100% copy of a PEAK-System internal Sample code -copied 1:1
It is not public - It have nothing to do with the request
** Forum Admin **
Re: Receive Signal
Post by PEAK-Support » Tue 13. Feb 2024, 07:54
It's not particularly helpful if you ask questions in the forum and send them by email at the same time.
One query is enough to get the answer. There is no "on receive" in VB Script using PCAN Explorer.
The rest of your code is copied 1:1 from one of our examples (why ?!?) and unfortunately has no connection to your actual question.
If you have a question about using PE6, ask, but please do not copy some of our sample code and post it here.
We will close this Thread here and if you have any questions please use then ONLY the E-Mail support and do not post here and send a e-mail for the same request.
Locked
