PLIN API on Python 3.11.4: Read queue delays
luciangu
Post by luciangu » Mon 8. Apr 2024, 12:17
Hello!
I'm using PLinApi.py to automate the LIN communication between a Master and a Slave through a board (that work as a gateway application).
In my implementation I read the ldf file and get info about the schedule table which use 2 unconditional frames:
- 0x30, 1 byte length (Publisher on Master side, Subscriber on Slave side)
- 0x33, 6 bytes length (Subscriber on Master side, Publisher on Slave side)
First I'm connecting to the HW as Master, update the Global Table with info about these frames, create and start the schedule table. Then I'm connecting to the HW as Slave and update the Global Table. All good at these steps.
The issue appear on read side where I'm receiving the data on frames with a lot of delay, sometimes with data updated on a previous run of a script. Looks like the queue is not flushed. With the PLin View Pro all works perfect, with load ldf or by creating manually the Global Table/Schedule table (like I did in the script.
I also tried to use the GUI example from the PLIN Api Samples (PLIN_API_Example3.pyw) but there I can read only once with Manual Read, than the GUI stacks.
Can you help me?
Here is my script (the Main function will be write in next comment - too many lines here):
import sys
import time
import ldfparser
from threading import Thread
from ctypes import *
import PLinApi
class PLinApiFunc:
    def __init__(self):
        self.initialize()
    def initialize(self):
        Initialize LIN attributes
        Parameters:
            None
        Returns:
            None
        # API configuration
        self.m_objPLinApi = PLinApi.PLinApi()
        if (not self.m_objPLinApi.isLoaded()):
            raise Exception("PLin-API could not be loaded ! Exiting...")
        # configure LIN variables
        self.m_hClient = PLinApi.HLINCLIENT(0)
        self.m_hHw = PLinApi.HLINHW(0)
        self.m_HwMode = PLinApi.TLIN_HARDWAREMODE_NONE
        self.m_HwBaudrate = c_ushort(0)
        self.FRAME_FILTER_MASK = c_uint64(0xFFFFFFFFFFFFFFFF)
        self.m_lMask = self.FRAME_FILTER_MASK
        # initialize a dictionnary to get LIN ID from PID
        self.PIDs = {}
        for i in range(64):
            nPID = c_ubyte(i)
            self.m_objPLinApi.GetPID(nPID)
            self.PIDs[nPID.value] = i
    def uninitialize(self):
        Uninitialize LIN attributes
        Parameters:
            None
        Returns:
            None
        # disconnect from LIN if necessary
        if (self.m_hClient.value != PLinApi.HLINCLIENT(0).value):
            self.do_lin_disconnect()
            # Unregister the application
            self.m_objPLinApi.RemoveClient(self.m_hClient)
    # LIN functions
    def do_lin_connect(self, clientName, hwHandle, hwMode, hwBaudrate):
        Connects to a LIN hardware.
        Parameters:
            clientName : str
                Name of the Client (python string)
            hwHandle : int
                LIN hardware handle (HLINHW) - index
                from display_available_connection()
            hwMode : str
                LIN hardware mode Master or Slave
                (see TLIN_HARDWAREMODE_MASTER and TLIN_HARDWAREMODE_SLAVE)
            hwBaudrate : int
                LIN hardware baudrate (c_ushort)
        Returns:
            bool
                True if connection is successful, False otherwise
        # Variables initialization
        result = False
        hwHandle = PLinApi.HLINHW(int(hwHandle))
        if hwMode.upper() == "MASTER":
            hwMode = PLinApi.TLIN_HARDWAREMODE_MASTER
        elif hwMode.upper() == "SLAVE":
            hwMode = PLinApi.TLIN_HARDWAREMODE_SLAVE
        else:
            print("Connection Error: No Master or Slave hardware mode \
                  selected.")
        hwBaudrate = c_ushort(int(hwBaudrate))
        # If a connection to the same hardware channel
        # already exits, disconnect this connection first.
        if (self.m_hHw.value == hwHandle):
            if (not self.doLinDisconnect()):
                return result
        # register LIN client
        print("Connection status for client name <{}>:".format(clientName))
        if (self.m_hClient.value == 0):
            self.m_objPLinApi.RegisterClient(
                clientName, None, self.m_hClient)
        else:
        # Try to connect the application client to the hardware with the local
        # handle.
        linResult = self.m_objPLinApi.ConnectClient(self.m_hClient, hwHandle)
        if (linResult == PLinApi.TLIN_ERROR_OK):
            # If the connection successfull assign
            # the local handle to the member handle.
            self.m_hHw = hwHandle
            # read hardware's parameter
            lnMode = c_int(0)
            lnCurrBaud = c_int(0)
            linResult = self.m_objPLinApi.GetHardwareParam(
                hwHandle, PLinApi.TLIN_HARDWAREPARAM_MODE, lnMode, 0)
                hwHandle, PLinApi.TLIN_HARDWAREPARAM_BAUDRATE, lnCurrBaud, 0)
            # check if initialization is required
            if (lnMode.value == PLinApi.TLIN_HARDWAREMODE_NONE.value or
                    lnCurrBaud.value != hwBaudrate.value):
                # Only if the current hardware is not initialized
                # try to Intialize the hardware with mode and baudrate
                linResult = self.m_objPLinApi.InitializeHardware(
                    self.m_hClient, self.m_hHw, hwMode, hwBaudrate)
                self.m_HwMode = hwMode
                self.m_HwBaudrate = hwBaudrate
                # Set the client filter with the mask.
                linResult = self.m_objPLinApi.SetClientFilter(
                    self.m_hClient, self.m_hHw, self.m_lMask)
                # Read the frame table from the connected hardware.
                self.read_frame_table_from_hw()
                # Reset the last LIN error code to default.
                linResult = PLinApi.TLIN_ERROR_OK
                result = True
            else:
                # An error occured while initializing hardware.
                # Set the member variable to default.
                result = False
        else:
            # The local hardware handle is invalid
            # and/or an error occurs while connecting
            # hardware with client.
            result = False
        if (linResult != PLinApi.TLIN_ERROR_OK):
            self.display_error(linResult)
        return result
    def do_lin_disconnect(self):
        Disconnects an existing connection to a LIN hardware
        Parameters:
            None
        Returns:
            None
        # If the application was registered with LIN as client.
        if (self.m_hHw.value != 0):
            # The client was connected to a LIN hardware.
            # Before disconnect from the hardware check
            # the connected clients and determine if the
            # hardware configuration have to reset or not.
            # Initialize the locale variables.
            lfOtherClient = False
            lfOwnClient = False
            lhClientsSize = c_ushort(255)
            lhClients = (PLinApi.HLINCLIENT * lhClientsSize.value)()
            # Get the connected clients from the LIN hardware.
                self.m_hHw, PLinApi.TLIN_HARDWAREPARAM_CONNECTED_CLIENTS,
                lhClients, lhClientsSize)
                # No errors !
                # Check all client handles.
                for i in range(1, lhClientsSize.value):
                    # If client handle is invalid
                    if (lhClients[i] == 0):
                        continue
                    # Set the boolean to true if the handle isn't the
                    # handle of this application.
                    # Even the boolean is set to true it can never
                    # set to false.
                    lfOtherClient = lfOtherClient | (
                        lhClients[i] != self.m_hClient.value)
                    # Set the boolean to true if the handle is the
                    # set to false.
                    lfOwnClient = lfOwnClient | (
                        lhClients[i] == self.m_hClient.value)
            # If another application is also connected to
            # the LIN hardware do not reset the configuration.
            if not lfOtherClient:
                # No other application connected !
                # Reset the configuration of the LIN hardware.
                linResult = self.m_objPLinApi.ResetHardwareConfig(
                    self.m_hClient, self.m_hHw)
            # If this application is connected to the hardware
            # then disconnect the client. Otherwise not.
            if lfOwnClient:
                # Disconnect if the application was connected to a LIN
                # hardware.
                linResult = self.m_objPLinApi.DisconnectClient(
                    return True
                else:
                    # Error while disconnecting from hardware.
                    return False
            else:
                return True
        else:
            # m_hHw not connected
            return True
    def read_frame_table_from_hw(self):
        Reads all values from the frame table of the hardware.
        Parameters:
            None
        Returns:
            result : list
                A global frame List of frame entry retrieved from the hardware
        # Initialize result
        result = []
        # Initialize the member attribute for the
        # client mask with the initialized mask.
        llMask = self.m_lMask
        # Read each Frame Definition
        for i in range(64):
            # Before a frame entry can be read from the
            # hardware, the Frame-ID of the wanted entry
            # must be set
            lFrameEntry = PLinApi.TLINFrameEntry()
            lFrameEntry.FrameId = c_ubyte(i)
            lFrameEntry.ChecksumType = PLinApi.TLIN_CHECKSUMTYPE_AUTO
            lFrameEntry.Direction = PLinApi.TLIN_DIRECTION_SUBSCRIBER_AUTOLENGTH
            # length values is set to LIN 1.2.
            if ((i >= 0x00) and (i <= 0x1F)):
                lFrameEntry.Length = c_ubyte(2)
            elif ((i >= 0x20) and (i <= 0x2F)):
                lFrameEntry.Length = c_ubyte(4)
            elif ((i >= 0x30) and (i <= 0x3F)):
                lFrameEntry.Length = c_ubyte(8)
            # Read the information of the specified frame entry from the
            # hardware.
            linResult = self.m_objPLinApi.GetFrameEntry(
                self.m_hHw, lFrameEntry)
            # Check the result value of the LinApi function call.
                result.append(lFrameEntry)
                # Update the local application mask according to the frame
                # configuration
                if (lFrameEntry.Direction != PLinApi.TLIN_DIRECTION_DISABLED.value):
                    llMask = c_uint64((1 << i) & self.FRAME_FILTER_MASK.value)
                    self.m_lMask = c_uint64(self.m_lMask.value | llMask.value)
            # If the Client and Hardware handles are valid.
            if ((self.m_hClient.value != 0) and (self.m_hHw.value != 0)):
                # Set the client filter.
        return result
    def set_global_frame_table(self, list_exception):
        Set all values from the frame table of the hardware.
        Parameters:
            None
        Returns:
            None
        for i in range(64):
            if i not in list_exception:
                lFrameEntry.ChecksumType = PLinApi.TLIN_CHECKSUMTYPE_ENHANCED
                lFrameEntry.Direction = PLinApi.TLIN_DIRECTION_DISABLED
                linResult = self.m_objPLinApi.SetFrameEntry(
                    self.m_hClient, self.m_hHw, lFrameEntry)
                    pass
                else:
                    print("Error - Global Frame Table cannot be set \
                          for id: {}".format(hex(i)))
    def get_available_hw(self):
        Returns a 2D list of available hardware.
        Each row describes a LIN hardware with, in order, its handle,
        type, device and channel number
        Parameters:
            None
        Returns:
            res : list
                A list of LIN hardware information, the imbricated list
                is composed like so [handle, type, device_number,
                channel_number]
        # Initialization
        res = []
        # Get the buffer length needed...
        lwCount = c_ushort(0)
        availableHWs = (PLinApi.HLINHW * 0)()
        linResult = self.m_objPLinApi.GetAvailableHardware(availableHWs,
                                                           0, lwCount)
        if (lwCount == 0):
            # use default value if either no hw is connected or an unexpected
            # error occured
            lwCount = c_ushort(16);
        availableHWs = (PLinApi.HLINHW * lwCount.value)()
        lwBuffSize = c_ushort(lwCount.value * 2)
            availableHWs, lwBuffSize, lwCount)
            # Get information for each LIN hardware found
            lnHwType = c_int(0)
            lnDevNo = c_int(0)
            lnDevId = c_int(0)
            lnChannel = c_int(0)
            lnMode = c_int(0)
            for i in range(lwCount.value):
                lwHw = availableHWs[i]
                # Read the type of the hardware with the handle lwHw.
                    lwHw, PLinApi.TLIN_HARDWAREPARAM_TYPE, lnHwType, 0)
                # Read the device number of the hardware with the handle lwHw.
                    lwHw, PLinApi.TLIN_HARDWAREPARAM_DEVICE_NUMBER, lnDevNo, 0)
                # Read the device id of the hardware with the handle lwHw.
                    lwHw, PLinApi.TLIN_HARDWAREPARAM_ID_NUMBER, lnDevId, 0)
                # Read the channel number of the hardware with the handle lwHw.
                    lwHw, PLinApi.TLIN_HARDWAREPARAM_CHANNEL_NUMBER,
                    lnChannel, 0)
                # Read the mode of the hardware with the handle lwHw (Master,
                # Slave or None).
                    lwHw, PLinApi.TLIN_HARDWAREPARAM_MODE, lnMode, 0)
                # translate type value to string
                if (lnHwType.value == PLinApi.LIN_HW_TYPE_USB_PRO.value):
                    strName = "PCAN-USB Pro"
                elif (lnHwType.value == PLinApi.LIN_HW_TYPE_USB_PRO_FD.value):
                    strName = "PCAN-USB Pro FD"
                elif (lnHwType.value == PLinApi.LIN_HW_TYPE_PLIN_USB.value):
                    strName = "PLIN-USB"
                else:
                    strName = "Unknown"
                # add information to result list
                res.append([strName, lnDevNo.value, lnChannel.value,
                            lwHw, hex(lnDevId.value & self.m_lMask.value)])
        return res
    def get_frame_direction_as_string(self, direction):
        Returns the string name of a PLinApi.TLINDirection value
        Parameters:
            direction : int
                a PLinApi.TLINDirection value (or a number)
        Returns:
            str
                a string name of the direction value
        # check given parameter
        if (isinstance(direction, PLinApi.TLINDirection)):
            value = direction.value
        else:
            value = int(direction)
        # translate value to string
        if (value == PLinApi.TLIN_DIRECTION_DISABLED.value):
            return 'Disabled'
        elif (value == PLinApi.TLIN_DIRECTION_PUBLISHER.value):
            return 'Publisher'
        elif (value == PLinApi.TLIN_DIRECTION_SUBSCRIBER.value):
            return 'Subscriber'
        elif (value == PLinApi.TLIN_DIRECTION_SUBSCRIBER_AUTOLENGTH.value):
            return 'Subscriber Automatic Length'
    def get_frame_cst_as_string(self, checksumType):
        Returns the string name of a PLinApi.TLINChecksumType value
        Parameters:
            checksumType : int
                a PLinApi.TLINChecksumType value (or a number)
        Returns:
            str
                a string name of the checksum type value
        if (isinstance(checksumType, PLinApi.TLINDirection)):
            value = checksumType.value
        else:
            value = int(checksumType)
        if (value == PLinApi.TLIN_CHECKSUMTYPE_AUTO.value):
            return 'Auto'
        elif (value == PLinApi.TLIN_CHECKSUMTYPE_CLASSIC.value):
            return 'Classic'
        elif (value == PLinApi.TLIN_CHECKSUMTYPE_CUSTOM.value):
            return 'Custom'
        elif (value == PLinApi.TLIN_CHECKSUMTYPE_ENHANCED.value):
            return 'Enhanced'
    def get_slot_type_as_string(self, slotType):
        Returns the string name of a PLinApi.TLINSlotType value
        Parameters:
            slotType : int
                a PLinApi.TLINSlotType value (or a number)
        Returns:
            str
                a string name of the slot type value
        if (isinstance(slotType, PLinApi.TLINSlotType)):
            value = slotType.value
        else:
            value = int(slotType)
        if (value == PLinApi.TLIN_SLOTTYPE_UNCONDITIONAL.value):
            return 'Unconditional'
        elif (value == PLinApi.TLIN_SLOTTYPE_EVENT.value):
            return 'Event'
        elif (value == PLinApi.TLIN_SLOTTYPE_SPORADIC.value):
            return 'Sporadic'
        elif (value == PLinApi.TLIN_SLOTTYPE_MASTER_REQUEST.value):
            return 'Master Request'
        elif (value == PLinApi.TLIN_SLOTTYPE_SLAVE_RESPONSE.value):
            return 'Slave Response'
    def get_formatted_rcv_msg(self, msg, conn_mode):
        Returns a string formatted LIN receive message
        Parameters:
            msg : LIN message
                a Lin receive message (TLINRcvMsg)
            conn_mode : str
                one of the values: MASTER or SLAVE
        Returns:
            str
                a string formatted LIN message
        # Check if the received frame is a standard type.
        # If it is not a standard type then ignore it.
        if (msg.Type != PLinApi.TLIN_MSGTYPE_STANDARD.value):
            if (msg.Type == PLinApi.TLIN_MSGTYPE_BUS_SLEEP.value):
                strTemp = 'Bus Sleep status message'
            elif (msg.Type == PLinApi.TLIN_MSGTYPE_BUS_WAKEUP.value):
                strTemp = 'Bus WakeUp status message'
            elif (msg.Type == PLinApi.TLIN_MSGTYPE_AUTOBAUDRATE_TIMEOUT.value):
                strTemp = 'Auto-baudrate Timeout status message'
            elif (msg.Type == PLinApi.TLIN_MSGTYPE_AUTOBAUDRATE_REPLY.value):
                strTemp = 'Auto-baudrate Reply status message'
            elif (msg.Type == PLinApi.TLIN_MSGTYPE_OVERRUN.value):
                strTemp = 'Bus Overrun status message'
            elif (msg.Type == PLinApi.TLIN_MSGTYPE_QUEUE_OVERRUN.value):
                strTemp = 'Queue Overrun status message'
            else:
                strTemp = 'Non standard message'
            return strTemp
        # format Data field as string
        dataStr = ""
        for i in range(msg.Length):
            if conn_mode.upper() == 'SLAVE' and (self.get_frame_direction_as_string(msg.Direction) == 'Subscriber' or
                self.get_frame_direction_as_string(msg.Direction) == 'Subscriber Automatic Length'):
                dataStr = str.format("{0}{1} ", dataStr,  hex(msg.Data[i] ^ int(0xFF)))
            else:
                dataStr = str.format("{0}{1} ", dataStr,  hex(msg.Data[i]))
        # remove ending space
        dataStr = dataStr[:-1]
        # format Error field as string
        error = ""
        if (msg.ErrorFlags & PLinApi.TLIN_MSGERROR_CHECKSUM):
            error = error + 'Checksum,'
        if (msg.ErrorFlags & PLinApi.TLIN_MSGERROR_GROUND_SHORT):
            error = error + 'GroundShort,'
        if (msg.ErrorFlags & PLinApi.TLIN_MSGERROR_ID_PARITY_BIT_0):
            error = error + 'IdParityBit0,'
        if (msg.ErrorFlags & PLinApi.TLIN_MSGERROR_ID_PARITY_BIT_1):
            error = error + 'IdParityBit1,'
        if (msg.ErrorFlags & PLinApi.TLIN_MSGERROR_INCONSISTENT_SYNCH):
            error = error + 'InconsistentSynch,'
        if (msg.ErrorFlags & PLinApi.TLIN_MSGERROR_OTHER_RESPONSE):
            error = error + 'OtherResponse,'
        if (msg.ErrorFlags & PLinApi.TLIN_MSGERROR_SLAVE_NOT_RESPONDING):
            error = error + 'SlaveNotResponding,'
        if (msg.ErrorFlags & PLinApi.TLIN_MSGERROR_SLOT_DELAY):
            error = error + 'SlotDelay,'
        if (msg.ErrorFlags & PLinApi.TLIN_MSGERROR_TIMEOUT):
            error = error + 'Timeout,'
        if (msg.ErrorFlags & PLinApi.TLIN_MSGERROR_VBAT_SHORT):
            error = error + 'VBatShort,'
        if (msg.ErrorFlags == 0):
            error = 'O.k. '
        # remove ending comma
        error = error[:-1]
        # format message
        return (str.format("{0}\t {1}\t{2}\n\t\t\t{3}\t{4}\t{5}\t{6}",
                           hex(self.PIDs[msg.FrameId]),
                           msg.Length,
                           dataStr,
                           (msg.TimeStamp),
                           self.get_frame_direction_as_string(msg.Direction),
                           hex(msg.Checksum),
                           error
    def set_frame_entry(self, frameId, direction, checksumType, length):
        Updates a frame entry of the global frames table.
        Parameters:
            frameId : hex
                frame ID to update (hex: 0xXX)
            direction : str
                one of the values: DISABLED, PUBLISHER, SUBSCRIBER,
                SUBSCRIBER AUTOLENGTH
            checksumType : str
                one of the values: CUSTOM, CLASSIC, ENHANCED, AUTO
            length : int
                length of the frame (int)
        Returns:
            bool
                True if frame successfully updated, False otherwise
        # initialize default values
        res = True
        # initialize and set Frame entry
        lFrameEntry.FrameId = c_ubyte(frameId)
        lFrameEntry.Length = c_ubyte(length)
        #   translate checksum parameter to PLinAPI value
        if checksumType.upper() == 'CUSTOM':
            checksum_type = PLinApi.TLIN_CHECKSUMTYPE_CUSTOM
        elif checksumType.upper() == 'CLASSIC':
            checksum_type = PLinApi.TLIN_CHECKSUMTYPE_CLASSIC
        elif checksumType.upper() == 'ENHANCED':
            checksum_type = PLinApi.TLIN_CHECKSUMTYPE_ENHANCED
        elif checksumType.upper() == 'AUTO':
            checksum_type = PLinApi.TLIN_CHECKSUMTYPE_AUTO
        #   translate direction parameter to PLinAPI value
        if direction.upper() == 'DISABLED':
        elif direction.upper() == 'PUBLISHER':
            lFrameEntry.Direction = PLinApi.TLIN_DIRECTION_PUBLISHER
            lFrameEntry.ChecksumType = checksum_type
            lFrameEntry.Flags = PLinApi.FRAME_FLAG_RESPONSE_ENABLE
        elif direction.upper() == 'SUBSCRIBER':
        elif direction.upper() == 'SUBSCRIBER AUTOLENGTH':
        # set frame entry
            # update filter mask to match the new status of the frame
            lMask = c_uint64(1 << frameId)
            self.m_lMask = c_uint64(self.m_lMask.value | lMask.value)
            res = False
        print("+ {}\t{}\t{}\t{}".format(
            hex(lFrameEntry.FrameId),
            self.get_frame_cst_as_string(lFrameEntry.ChecksumType),
            self.get_frame_direction_as_string(lFrameEntry.Direction),
            lFrameEntry.Length))
        return res
    def display_global_frames_table(self, showDisabled=False):
        Displays LIN Global Frames table
        Parameters:
            showDisabled : bool
                defines if disabled frame should be included (boolean)
        Returns:
            str
                A string table with the Global Frames
        # get global frames table
        pGFT = self.read_frame_table_from_hw()
        # print results
        print("\n * Global Frames Table:\n")
        print(" ID\tPID\tDirection\t\tLength\tChecksum Type")
        print(" ------------------------------------------------------------")
        nPID = c_ubyte(0)
        # output each frame
        for frame in pGFT:
            nPID = c_ubyte(frame.FrameId)
            # if showDisabled is false, check wether the frame is enabled
            if (frame.Direction != PLinApi.TLIN_DIRECTION_DISABLED.value or
                    (frame.Direction == PLinApi.TLIN_DIRECTION_DISABLED.value
                     and showDisabled)
                print(str.format(" {0}\t{1}\t{2}\t\t{3}\t{4}\t",
                                 hex(frame.FrameId),
                                 hex(nPID.value),
                                     frame.Direction),
                                 frame.Length,
                                     frame.ChecksumType)
        print(" ------------------------------------------------------------\n")
    def create_schedule_slots(self, noOfSlots):
        Create an array of schedule slots where the slots for Schedule table
        will be defined
        Parameters:
            noOfSlots : int
                Number of slots that will be created.
        Returns:
            scheduleTable : TLINScheduleSlot Array class
                A TLINScheduleSlot array class
        # Create a list of schedule slots
        scheduleList = (PLinApi.TLINScheduleSlot * noOfSlots)
        scheduleTable = scheduleList()
        return scheduleTable
    def set_slot_attributes(self, scheduleArrayObj, frameId,
                            slot_type, frameDelay, slotIndex):
        Update schedule slot with info from the frame that will
        run in the schedule table
        Parameters:
            scheduleArrayObj : obj
                Array object created by the 'create_schedule_slots' method.
            frameId : hex
                The ID of the frame that will be present in the Schedule Table
            slot_type : str
                Slot Type of the frame. Can take one of the following values:
                Unconditional, Event, Sporadic, Master Request, Slave Response
            frameDelay : int
                The delay of the frame (in ms)
            slotIndex : int
                Index of the slot from the 'scheduleArrayObj' array
        Returns:
            None
        # Set attributes for each slot
        scheduleEntry = PLinApi.TLINScheduleSlot()
        scheduleEntry.FrameId[0] = c_ubyte(frameId)
        scheduleEntry.Delay = c_ushort(frameDelay)
        #   translate slot type parameter to PLinAPI value
        if slot_type.upper() == 'UNCONDITIONAL':
            scheduleEntry.Type = PLinApi.TLIN_SLOTTYPE_UNCONDITIONAL
        elif slot_type.upper() == 'EVENT':
            scheduleEntry.Type = PLinApi.TLIN_SLOTTYPE_EVENT
            scheduleEntry.CountResolve = c_ubyte(0) #TBD
        elif slot_type.upper() == 'SPORADIC':
            scheduleEntry.Type = PLinApi.TLIN_SLOTTYPE_SPORADIC
        elif slot_type.upper() == 'MASTER REQUEST':
            scheduleEntry.Type = PLinApi.TLIN_SLOTTYPE_MASTER_REQUEST
        elif slot_type.upper() == 'SLAVE RESPONSE':
            scheduleEntry.Type = PLinApi.TLIN_SLOTTYPE_SLAVE_RESPONSE
        #scheduleEntry.CountResolve = c_ubyte(0)
        scheduleArrayObj[slotIndex] = scheduleEntry
    def set_schedule(self, scheduleTableId, scheduleSlotList, slotsNumber):
        Set (configure) the slots in the Schedule Table,
        defined in 'set_slot_attributes' method
        Parameters:
            scheduleTableId : int
                id (number) of the chedule (int). start with 0
            scheduleSlotList : list
                the list with the schedule slots set (list)
            numberOfSlots : int
                defines number of Schedule Slots to be created (int)
        Returns:
            None
        scheduleTableId = c_ubyte(scheduleTableId)
        # Call the SetSchedule LIN API method
        linResult = self.m_objPLinApi.SetSchedule(
            self.m_hClient, self.m_hHw, scheduleTableId, scheduleSlotList,
            slotsNumber)
            print("Set Schedule Table Done")
        else:
            print("Error - Schedule Table not set")
    def get_schedule(self, scheduleTableId):
        Return the Schedule Table if was defined before,
        based on the the Schedule Table ID
        Parameters:
        Returns:
            str
                A string table with the frames and details of it from the
                Schedule Table
        schedule_slot_array = (PLinApi.TLINScheduleSlot * 256)
        schedule_table = schedule_slot_array()
        count = c_int(0)
        linResult = self.m_objPLinApi.GetSchedule(
            self.m_hHw, scheduleTableId, schedule_table,
            c_int(256), count)
            print("Get Schedule Table - Done")
        else:
            print("Error - Schedule Table cannot be returned")
        # Print schedule table
        frames = self.read_frame_table_from_hw()
        print("\n * Schedule Table:\n")
        print(" ID\tDelay\tSlot Type\tDirection\tChecksum Type")
        for index in range(count.value):
            schedule_entry = schedule_table[index]
            for frame in frames:
                if hex(frame.FrameId) == hex(schedule_entry.FrameId[0]):
                    fr_direction = frame.Direction
                    fr_checksum = frame.ChecksumType
            print(" {}\t{}\t{}\t{}\t{}\t".format(
                hex(schedule_entry.FrameId[0]),
                schedule_entry.Delay,
                self.get_slot_type_as_string(schedule_entry.Type),
                self.get_frame_direction_as_string(fr_direction),
                self.get_frame_cst_as_string(fr_checksum))
        print(" ---------------------------------------------\
              ---------------\n")
    def start_schedule(self, scheduleTableId):
        Start the selected Schedule Table
        Parameters:
        Returns:
            None
        # Call the StartSchedule LIN API method
        linResult = self.m_objPLinApi.StartSchedule(
            self.m_hClient, self.m_hHw, scheduleTableId)
            print("Schedule Table is running")
        else:
            print("Error - Schedule Table cannot run", linResult)
    def suspend_schedule(self):
        Suspend the Schedule Table run
        Parameters:
            None
        Returns:
            None
        # Call the SuspendSchedule LIN API method
        linResult = self.m_objPLinApi.SuspendSchedule(
            print("Schedule Table run Suspended")
        else:
            print("Error - Schedule Table run canot be Suspended")
    def resume_schedule(self):
        Resume the Schedule Table run
        Parameters:
            None
        Returns:
            None
        # Call the ResumeSchedule LIN API method
        linResult = self.m_objPLinApi.ResumeSchedule(
            print("ResumeSchedule Done")
        else:
            print("ResumeSchedule Error")
    def delete_schedule(self, scheduleTableId):
        Delete the definedSchedule Table by schedule table ID
        Parameters:
        Returns:
            None
        # Call the DeleteSchedule LIN API method
        linResult = self.m_objPLinApi.DeleteSchedule(
            print("Schedule Table Deleted")
        else:
            print("Error - Schedule Table cannot be Deleted")
    def reset_hw(self):
        Flushes the queues of the Hardware and resets its counters.
        Parameters:
            None
        Returns:
            None
        # Call the ResetHardware LIN API method
        linResult = self.m_objPLinApi.ResetHardware(self.m_hClient,
                                                          self.m_hHw)
            print("Reset Hardware Done")
        else:
            print("Error - Hardware cannot be reset")
    def reset_hw_config(self):
        Deletes the current configuration of the Hardware and sets its
        defaults.
        The Client 'm_hClient' must be registered and connected to the
        Hardware to  be accessed.
        Parameters:
            None
        Returns:
            None
        # Call the ResetHardwareConfig LIN API method
        linResult = self.m_objPLinApi.ResetHardwareConfig(self.m_hClient,
                                                          self.m_hHw)
            print("Reset Hardware Config Done")
        else:
            print("Error - Hardware Config cannot be reset")
    def wake_up(self):
        Sends a wake-up message impulse (single data byte 0xF0). The Client
        'hClient' must be registered and connected to the Hardware to be
        accessed.
        Remark: Only in Slave-mode. After sending a wake-up impulse a time
        of 150 milliseconds is used as timeout.
        Parameters:
            None
        Returns:
            None
        # Call the XmtWakeUp LIN API method
        linResult = self.m_objPLinApi.XmtWakeUp(self.m_hClient, self.m_hHw)
            print("WakeUp Done")
        else:
            print("Error - WakeUp cannot be send")
    def wake_up_dynamic(self):
        accessed.
        Parameters:
            None
        Returns:
            None
        # Call the XmtDynamicWakeUp LIN API method
        linResult = self.m_objPLinApi.XmtDynamicWakeUp(self.m_hClient,
                                                       self.m_hHw, 3)
            print("Dynamic WakeUp Done")
        else:
            print("Error - Dynamic WakeUp cannot be send")
    def reset_client(self):
        Flushes the Receive Queue of the Client and resets its counters.
        Parameters:
            None
        Returns:
            None
        # Call the ResetClient LIN API method
        linResult = self.m_objPLinApi.ResetClient(self.m_hClient)
            print("Reset Client Done")
        else:
            print("Error - Client cannot be reseted")
    def remove_client(self):
        Removes a Client from the Client list of the LIN Manager.
        Frees all resources (receive queues, message counters, etc.).
        Parameters:
            None
        Returns:
            None
        # Call the RemoveClient LIN API method
        linResult = self.m_objPLinApi.RemoveClient(self.m_hClient)
            print("Remove Client Done")
        else:
            print("Error - Client cannot be removed")
    def read_msg(self, no_of_message_to_read, conn_mode):
        Read and display the read messages
        Parameters:
            no_of_message_to_read : int
                Number of messages to be readed
        Returns:
            None
        bQuit = False
        choice = no_of_message_to_read
        # buffer of received message
        listMsg = []
        while (not bQuit):
            # display received messages from previous loop
            if (len(listMsg) > 0):
                print('\n * Received messages:')
                print('\n   ID\tLength\tData\tTimestamp\tDirection\tChecksum\tErrors')
                print(
                for msg in listMsg:
                    print('\n - ' + msg)
                # clear messages so that they do not appear on th next loop
                listMsg = []
            if (choice == 'Q'):
                bQuit = True
            else:
                try:
                    # read a single message
                    if (choice == 0 or choice == 1):
                        # initialize and read a LIN message
                        pRcvMsg = PLinApi.TLINRcvMsg()
                        linResult = self.m_objPLinApi.Read(
                            self.m_hClient, pRcvMsg)
                            # append received message to message list
                            listMsg.append(self.get_formatted_rcv_msg(pRcvMsg, conn_mode))
                        elif (linResult == PLinApi.TLIN_ERROR_RCVQUEUE_EMPTY):
                            self.display_error(linResult, False, 0.5)
                        else:
                        choice = 'Q'
                    else:
                        # read multiple LIN messages
                        nbRead = int(choice)
                        pRcvMsgArray = (PLinApi.TLINRcvMsg * nbRead)()
                        pRcvMsgCount = c_int(0)
                        linResult = self.m_objPLinApi.ReadMulti(
                            self.m_hClient, pRcvMsgArray, nbRead, pRcvMsgCount)
                        if (linResult == PLinApi.TLIN_ERROR_OK or
                            # Check wether there was no message or not enough
                            # to fill the array resulting in
                            # a TLIN_ERROR_RCVQUEUE_EMPTY
                            if (pRcvMsgCount.value == 0):
                            else:
                                # append received messages to message list
                                for i in range(pRcvMsgCount.value):
                                    listMsg.append(
                                        self.get_formatted_rcv_msg(pRcvMsgArray[i], conn_mode))
                        else:
                        choice = 'Q'
                except:
                    self.display_notification(text="Error on read message")
                    choice = 'Q'
        print('   -----------------------------------------------------------\n')
    def update_frame_data(self, frame_id, data=[]):
        Updata data of a frame that run in the Schedule Table
        Parameters:
            frame_id : hex
                ID of the frame which the data will be updated
            data : list
                A list with the bytes of new data
                (the bytes from the list can be in hex or int)
        Returns:
            None
        raw_data = (c_ubyte * len(data))()
        for index, byte in enumerate(data):
            raw_data[index] = c_ubyte(byte)
        linResult = self.m_objPLinApi.UpdateByteArray(
            self.m_hClient,
            self.m_hHw,
            c_ubyte(frame_id),
            0,
            c_ubyte(len(data)),
            raw_data)
            print("Frame ID {} successfully updated with value {}\n".format(
                hex(frame_id), list(map(hex, data))))
        else:
            print("Failed to update frame ID {} value/s.\n".format(hex(frame_id)))
    def write_msg(self, frame_id, data=[]):
        Write a message for a frame ID from the Global Table
        Parameters:
            frame_id : hex
                ID of the frame which the data will be written
            data : list
        Returns:
            None
        try:
            # set frame entry
            lFrameEntry.FrameId = c_ubyte(frame_id)
            # get data length from frame
            # initialize LIN message to sent
            pMsg = PLinApi.TLINMsg()
            pMsg.Direction = PLinApi.TLINDirection(
            pMsg.ChecksumType = PLinApi.TLINChecksumType(
            pMsg.Length = c_ubyte(lFrameEntry.Length)
            # query and fill data, only if direction is publisher
            if (pMsg.Direction == PLinApi.TLIN_DIRECTION_PUBLISHER.value):
                for i in range(lFrameEntry.Length):
                    pMsg.Data[i] = c_ubyte(int(data[i]))
            # Check if the hardware is initialized as master
            if (self.m_HwMode.value == PLinApi.TLIN_HARDWAREMODE_MASTER.value):
                # set frame id to Protected ID
                nPID = c_ubyte(frame_id)
                linResult = self.m_objPLinApi.GetPID(nPID)
                pMsg.FrameId = c_ubyte(nPID.value)
                # set checksum
                linResult = self.m_objPLinApi.CalculateChecksum(pMsg)
                # write LIN message
                linResult = self.m_objPLinApi.Write(
                    self.m_hClient, self.m_hHw, pMsg)
            else:
                # connected as slave : writing corresponds to updating
                # the data from LIN frame
                    self.m_hClient, self.m_hHw, c_ubyte(frame_id),
                    c_ubyte(0), c_ubyte(pMsg.Length), pMsg.Data)
                    "Message successfully written for frame ID {}".format(
                        hex(frame_id)))
            else:
                self.display_notification("Failed to write message for \
                                         frame ID {}".format(hex(frame_id)))
        except:
            # catch all exception (LIN, bad input)
            self.display_notification()
    def display_notification(self, text="** Error **", waitSeconds=0.5):
        Prints a notification
        Parameters:
            text : str
                custom text to display to the user
            waitSeconds : float
                number of seconds to wait after displaying notification
        Returns:
            None
        print(str.format("\t{0}", text))
        time.sleep(waitSeconds)
    def bus_status(self):
        Print the current bus status
        Parameters:
            None
        Returns:
            None
        # Retrieves the status of the LIN Bus and outputs its state
        pStatus = PLinApi.TLINHardwareStatus()
        linResult = self.m_objPLinApi.GetStatus(self.m_hHw, pStatus)
            # output bus status
            if (pStatus.Status == PLinApi.TLIN_HARDWARESTATE_ACTIVE.value):
                self.display_notification('Bus: Active')
            elif (pStatus.Status == PLinApi.TLIN_HARDWARESTATE_AUTOBAUDRATE.value):
                self.display_notification('Hardware: Baudrate Detection')
            elif (pStatus.Status == PLinApi.TLIN_HARDWARESTATE_NOT_INITIALIZED.value):
                self.display_notification('Hardware: Not Initialized')
            elif (pStatus.Status == PLinApi.TLIN_HARDWARESTATE_SHORT_GROUND.value):
                self.display_notification('Bus-Line: Shorted Ground')
            elif (pStatus.Status == PLinApi.TLIN_HARDWARESTATE_SLEEP.value):
                self.display_notification('Bus: Sleep')
        else:
    def display_available_connection(self):
        Displays a list of available LIN hardwares.
        Parameters:
            None
        Returns:
            str
                A list of available LIN hardwares.
        # retrieve a list of available hardware
        hWInfoList = self.get_available_hw()
        # display result
        print(" List of available LIN hardware:")
        if (len(hWInfoList) == 0):
            print("\t<No hardware found>\n")
        else:
            # for each hardware display it's type, device and channel
            for hWInfo in hWInfoList:
                if (self.m_hHw.value == hWInfo[3]):
                        hwType = "master"
                    elif (self.m_HwMode.value == PLinApi.TLIN_HARDWAREMODE_SLAVE.value):
                        hwType = "slave"
                    # add information if the application is connecter to the
                    # hardware
                    isConnected = str.format("(connected as {0}, {1})",
                                             hwType, self.m_HwBaudrate.value)
                else:
                    isConnected = ""
                print(str.format('\t{3}) {0} - dev. {1}, chan. {2} {4}',
                                 hWInfo[0], hWInfo[1],
                                 hWInfo[2], hWInfo[3], isConnected))
        print("\n")
        return hWInfoList
    def display_error(self, linError, waitTime=0):
        Prints a LIN error message from the LIN API
        Parameters:
            linError : obj
                a LIN Error (TLinError)
        Returns:
            None
        # get error string from code
        pTextBuff = create_string_buffer(255)
        linResult = self.m_objPLinApi.GetErrorText(
            linError, 0x09, pTextBuff, 255)
        # display error message
        if (linResult == PLinApi.TLIN_ERROR_OK and len(pTextBuff.value) != 0):
                str.format("* Error * - {0} \n", bytes.decode(
                    pTextBuff.value)), waitTime)
        else:
                str.format("* Error * - code={0}\n", linError), waitTime)
    def connect_client(self, linHwDeviceId, connectionName,
                       hwConnectionMode, hwBaudrate=19200):
        Initiate a connection, Master or Slave, on the given hw ID
        Parameters:
            linHwDeviceId : str
                The LIN hw ID set in the PEAK Settings.
            connectionName : str
                A name given to the connection.
            hwConnectionMode : str
                The hw connection mode. Can be only 'MASTER' or 'SLAVE'
            hwBaudrate : int
                Hw baudrate. Default is 19200
        Returns:
            bool
                True if the connection succeed, False otherwise
        hwIndex = 0
        # Get and display LIN hardware available connections - device
        # and channel
        lin_hw_available = self.display_available_connection()
        # Identify LIN hw for the connection based on the given device ID
        for hw in lin_hw_available:
            if linHwDeviceId in str(hw[4]):
                hwIndex = hw[3]
        if hwIndex == 0:
            print("The HW ID provided is not pressent in the available \
                  hw list.")
        # Initiate the connection
        try:
            print("--> Init {} node conection on LIN hardware index {}".format(
                hwConnectionMode, hwIndex))
            if (self.do_lin_connect(connectionName, hwIndex, hwConnectionMode,
                                  hwBaudrate)):
                print("\tConnection Succesfull.\n")
                result = True
            else:
                print("\tConnection Failed.")
                result = False
        except:
            print("Error - Connection cannot be initiated.")
            result = False
        return result
    def parse_ldf(self, ldf_file_path, hwConnectionMode):
        Parse the ldf file and return the requested info from it
        Parameters:
            ldf_file_path : file path
                Path to the ldf file.
        Returns:
            frame_info : list of dictionaries
                A list of dictionaries that contain info about each frame
                from the Schedule Table, such as: id, boudrate, frame
                direction, frame length, delay, init data
        frame_info = []
        # Load the LDF file
        ldf_file = ldfparser.parse_ldf(ldf_file_path)
        # Get the node name from the hw connection mode
        if hwConnectionMode.upper() == 'MASTER':
            node_name = ldf_file.get_master().name
        elif hwConnectionMode.upper() == 'SLAVE':
            for i in ldf_file.get_slaves():
                node_name = i.name
        # Get each schedule table from Schedule Tables
        for table in ldf_file.get_schedule_tables():
            # For each schedule table from Schedule Tables, get the containing frames and the delay in ms
            for entry in ldf_file.get_schedule_table(table.name).schedule:
                frame_dict = {}
                conn_baudrate = ldf_file.get_baudrate()
                frame_name = entry.frame.name
                frame_delay = entry.delay * 1000
                # Based on the name of the frames from Schedule Table,
                # get a list of frames from UNCONDITIONAL FRAME DEFINITIONS
                # with the ID in hex and name
                for uncond_frame in ldf_file.get_unconditional_frames():
                    if uncond_frame.name == frame_name:
                        # for each frame, get the signals with the start bit, length and inital values
                        init_val_list = []
                        for signal in uncond_frame.signal_map:
                            signal_value = signal[1].init_value
                            if isinstance(signal_value, int):
                                init_val_list.append(signal_value)
                            else:
                                init_val_list += signal_value
                        # get the direction of the signal
                        if node_name == ldf_file.get_unconditional_frame(uncond_frame.name).publisher.name:
                            direction = 'PUBLISHER'
                        else:
                            direction = 'SUBSCRIBER'
                        # add info in the dictionary
                        frame_dict['id'] = uncond_frame.frame_id
                        frame_dict['baudrate'] = conn_baudrate
                        frame_dict['frDirection'] = direction
                        frame_dict['frLengthBytes'] = uncond_frame.length
                        frame_dict['delay'] = int(frame_delay)
                        frame_dict['initData'] = init_val_list
                # add dictionary in the list
                frame_info.append(frame_dict)
        return frame_info
    def get_time(self):
        hw_time=c_uint64(0)
        linResult = self.m_objPLinApi.GetTargetTime(self.m_hHw, hw_time)
            print(hw_time.value)
            return hw_time.value
        else:
            print("Error on GetTime")
            return None
luciangu
Re: Read queue with a lot of delay with Python
Post by luciangu » Mon 8. Apr 2024, 12:21
The main function (Delay on Master side: 50 ms; on Slave 25 ms):
if __name__ == "__main__":
    lin_obj_master = PLinApiFunc()
    lin_obj_slave = PLinApiFunc()
    lin_obj_master.uninitialize()
    lin_obj_slave.uninitialize()
    no_of_reads = 30
    # Get info from ldf file
    # Master
    connection_mode = 'Master'
    ldf_path = "C:\\Users\\nxf98042\\Desktop\\LIN21_master_gateway.ldf"
    schedule_table = lin_obj_master.parse_ldf(ldf_path, connection_mode)
    checksum_type = 'ENHANCED'
    # Slave
    connection_mode_s = 'Slave'
    ldf_path_s = "C:\\Users\\nxf98042\\Desktop\\LIN21_gateway_motor1.ldf"
    schedule_table_s = lin_obj_slave.parse_ldf(ldf_path_s, connection_mode_s)
    checksum_type_s = 'ENHANCED'
    # Connect
    # params: <id of hw>, <connection name>, <connection mode>
    # Master
    if not lin_obj_master.connect_client('de344102', 'ConnectionMaster', connection_mode):
        sys.exit("Execution Stopped")
    time.sleep(1)
    # Set Frames from the Schedule table from the LDF file
    # Master
    print("\n\n * Frames configuration updated in the Global frames table of {} connection:\n".format(connection_mode))
    print("  ID\tChecksum Type\tDirection\tLength")
    exception_list = []
    frame_set_confirmation = True
    for frame in schedule_table:
        set_frame = lin_obj_master.set_frame_entry(frame['id'], frame['frDirection'], checksum_type, frame['frLengthBytes'])
        exception_list.append(int(frame['id']))
        if not set_frame:
            frame_set_confirmation = False
    if frame_set_confirmation:
        print("Frames configuration successfully updated for {} connection.\n".format(connection_mode))
    else:
        print("Frames configuration failed to be updated for {} connection.\n".format(connection_mode))
        sys.exit('Frame/s cannot be set in the Global Table')
    lin_obj_master.set_global_frame_table(exception_list)
    print("Master Global Table:")
    lin_obj_master.display_global_frames_table()
    # Master
    schedule_slot_array = lin_obj_master.create_schedule_slots(len(schedule_table))
        lin_obj_master.set_slot_attributes(schedule_slot_array, frame['id'], 'Unconditional', frame['delay'], schedule_table.index(frame))
        # Set the init values
        lin_obj_master.update_frame_data(frame['id'], frame['initData'])
    # Set schedule Table
    lin_obj_master.set_schedule(0, schedule_slot_array, len(schedule_table))
    # Start schedule
    # Master
    lin_obj_master.start_schedule(0)
    lin_obj_master.get_schedule(0)
    #________________________________________________________________________
    # Connect
    # Slave
    if not lin_obj_slave.connect_client('de344101', 'ConnectionSlave', connection_mode_s):
    time.sleep(1)
    # Slave
    print("\n\n * Frames configuration updated in the Global frames table of {} connection:\n".format(connection_mode_s))
    exception_list = []
    for frame in schedule_table_s:
        set_frame = lin_obj_slave.set_frame_entry(frame['id'], frame['frDirection'], checksum_type_s, frame['frLengthBytes'])
        if not set_frame:
        print("Frames configuration successfully updated for {} connection.\n".format(connection_mode_s))
    else:
        print("Frames configuration failed to be updated for {} connection.\n".format(connection_mode_s))
    lin_obj_slave.set_global_frame_table(exception_list)
    print("Slave Global Table:")
    lin_obj_slave.display_global_frames_table()
    #lin_obj_master.reset_hw()
    #lin_obj_slave.reset_hw()
    #lin_obj_master.reset_client()
    lin_obj_slave.reset_client()
    # Updata data from Slave
    print("Update value from Slave")
    lin_obj_slave.update_frame_data(0x33, [0x14, 0x00, 0x00, 0x00, 0x00, 0x00])
    # Read data in Master
    print("Read on Master")
    lin_obj_master.read_msg(no_of_reads, connection_mode)
    # Updata data from Master
    print("Update value from Master")
    lin_obj_master.update_frame_data(0x30, [0x01])
    # Read data in Slave
    print("Read on Slave")
    lin_obj_slave.read_msg(no_of_reads, connection_mode_s)
    lin_obj_master.update_frame_data(0x30, [0x02])
    lin_obj_master.update_frame_data(0x30, [0x03])
    lin_obj_slave.update_frame_data(0x33, [0xF4, 0x00, 0x00, 0x00, 0x00, 0x00])
    #Read data in Master
    lin_obj_master.suspend_schedule()
    lin_obj_master.delete_schedule(0)
    lin_obj_master.bus_status()
    lin_obj_slave.bus_status()
    # Master
    lin_obj_master.reset_hw_config()
    #lin_obj_master.display_global_frames_table()
    # Slave
    lin_obj_slave.reset_hw_config()
    #lin_obj_slave.display_global_frames_table()
    time.sleep(1)
    #Disconnect
    # Master
    if lin_obj_master.do_lin_disconnect():
        print("Disconnection Master succesfull")
    else:
        print("Disconnection Master failed")
    # Slave
    if lin_obj_slave.do_lin_disconnect():
        print("Disconnection Slave succesfull")
    else:
        print("Disconnection Slave failed")
    # Remove Client
    # Master
    lin_obj_master.remove_client()
    # Slave
    lin_obj_slave.remove_client()
And here you can find the logs from a run:
1) PCAN-USB Pro FD - dev. 1, chan. 1
2) PCAN-USB Pro FD - dev. 1, chan. 2
3) PCAN-USB Pro FD - dev. 2, chan. 1
4) PCAN-USB Pro FD - dev. 2, chan. 2
--> Init Master node conection on LIN hardware index 4
Connection status for client name <ConnectionMaster>:
4) PCAN-USB Pro FD - dev. 2, chan. 2 (connected as master, 19200)
* Frames configuration updated in the Global frames table of Master connection:
ID Checksum Type Direction Length
+ 0x30 Enhanced Publisher 1
+ 0x33 Enhanced Subscriber 6
Frames configuration successfully updated for Master connection.
ID PID Direction Length Checksum Type
0x30 0xf0 Publisher 1 Enhanced
0x33 0x73 Subscriber 6 Enhanced
Frame ID 0x30 successfully updated with value ['0x0']
Frame ID 0x33 successfully updated with value ['0x5', '0x0', '0x0', '0x0', '0x0', '0x0']
* Error * - No Error.
* Schedule Table:
ID Delay Slot Type Direction Checksum Type
0x30 50 Unconditional Publisher Enhanced
0x33 50 Unconditional Subscriber Enhanced
--> Init Slave node conection on LIN hardware index 3
Connection status for client name <ConnectionSlave>:
3) PCAN-USB Pro FD - dev. 2, chan. 1 (connected as slave, 19200)
* Frames configuration updated in the Global frames table of Slave connection:
+ 0x30 Enhanced Subscriber 1
+ 0x33 Enhanced Publisher 6
Frames configuration successfully updated for Slave connection.
Slave Global Table:
0x30 0xf0 Subscriber 1 Enhanced
0x33 0x73 Publisher 6 Enhanced
Reset Client Done
Frame ID 0x33 successfully updated with value ['0x14', '0x0', '0x0', '0x0', '0x0', '0x0']
Read on Master
ID Length Data Timestamp Direction Checksum Errors
- 0x30 1 0x0
528470276396 Publisher 0xf O.k.
- 0x33 6 0x0 0x0 0x0 0x0 0x0 0xfe
528470326384 Subscriber 0x8d O.k.
- 0x30 1 0x0
528470376378 Publisher 0xf O.k.
528470426372 Subscriber 0x8d O.k.
- 0x30 1 0x0
528470476366 Publisher 0xf O.k.
528470526360 Subscriber 0x8d O.k.
- 0x30 1 0x0
528470576354 Publisher 0xf O.k.
528470626348 Subscriber 0x8d O.k.
- 0x30 1 0x0
528470676342 Publisher 0xf O.k.
528470726235 Subscriber 0x8d O.k.
- 0x30 1 0x0
528470776231 Publisher 0xf O.k.
528470826224 Subscriber 0x8d O.k.
- 0x30 1 0x0
528470876218 Publisher 0xf O.k.
528470926212 Subscriber 0x8d O.k.
- 0x30 1 0x0
528470976206 Publisher 0xf O.k.
528471026200 Subscriber 0x8d O.k.
- 0x30 1 0x0
528471076195 Publisher 0xf O.k.
528471126188 Subscriber 0x8d O.k.
- 0x30 1 0x0
528471176182 Publisher 0xf O.k.
528471226176 Subscriber 0x8d O.k.
- 0x30 1 0x0
528471276171 Publisher 0xf O.k.
528471326163 Subscriber 0x8d O.k.
- 0x30 1 0x0
528471376158 Publisher 0xf O.k.
528471426151 Subscriber 0x8d O.k.
- 0x30 1 0x0
528471476146 Publisher 0xf O.k.
528471526140 Subscriber 0x8d O.k.
- 0x30 1 0x0
528471576134 Publisher 0xf O.k.
528471626128 Subscriber 0x8d O.k.
- 0x30 1 0x0
528471676122 Publisher 0xf O.k.
528471726216 Subscriber 0x8d O.k.
Reset Client Done
Frame ID 0x30 successfully updated with value ['0x1']
Read on Slave
- 0x33 6 0x0 0x0 0x0 0x0 0x0 0x0
528472814390 Publisher 0x8c O.k.
Frame ID 0x30 successfully updated with value ['0x2']
Read on Slave
Frame ID 0x30 successfully updated with value ['0x3']
Read on Slave
- 0x30 1 0x3
528472829366 Subscriber 0x12 O.k.
- 0x33 6 0x14 0x0 0x0 0x0 0x0 0x0
528472839400 Publisher 0x78 O.k.
- 0x30 1 0x3
528472854375 Subscriber 0x12 O.k.
528472864358 Publisher 0x78 O.k.
- 0x30 1 0x3
528472879385 Subscriber 0x12 O.k.
528472889369 Publisher 0x78 O.k.
- 0x30 1 0x1
528472904395 Subscriber 0x10 O.k.
528472914379 Publisher 0x78 O.k.
- 0x30 1 0x1
528472929353 Subscriber 0x10 O.k.
528472939389 Publisher 0x78 O.k.
- 0x30 1 0x1
528472954364 Subscriber 0x10 O.k.
528472964347 Publisher 0x78 O.k.
- 0x30 1 0x1
528472979374 Subscriber 0x10 O.k.
528472989357 Publisher 0x78 O.k.
- 0x30 1 0x1
528473004384 Subscriber 0x10 O.k.
528473014368 Publisher 0x78 O.k.
- 0x30 1 0x1
528473029342 Subscriber 0x10 O.k.
528473039378 Publisher 0x78 O.k.
- 0x30 1 0x1
528473054353 Subscriber 0x10 O.k.
528473064388 Publisher 0x78 O.k.
- 0x30 1 0x1
528473079363 Subscriber 0x10 O.k.
528473089346 Publisher 0x78 O.k.
- 0x30 1 0x1
528473104373 Subscriber 0x10 O.k.
528473114356 Publisher 0x78 O.k.
- 0x30 1 0x1
528473129383 Subscriber 0x10 O.k.
528473139367 Publisher 0x78 O.k.
- 0x30 1 0x1
528473154341 Subscriber 0x10 O.k.
528473164377 Publisher 0x78 O.k.
- 0x30 1 0x1
528473179352 Subscriber 0x10 O.k.
528473189335 Publisher 0x78 O.k.
Frame ID 0x33 successfully updated with value ['0xf4', '0x0', '0x0', '0x0', '0x0', '0x0']
Read on Master
528472825984 Subscriber 0x8d O.k.
- 0x30 1 0x2
528472875978 Publisher 0xd O.k.
- 0x33 6 0x14 0x0 0x0 0x0 0x0 0xfe
528472925971 Subscriber 0x79 O.k.
- 0x30 1 0x2
528472975966 Publisher 0xd O.k.
528473025959 Subscriber 0x79 O.k.
- 0x30 1 0x2
528473075954 Publisher 0xd O.k.
528473125948 Subscriber 0x79 O.k.
- 0x30 1 0x2
528473175942 Publisher 0xd O.k.
528473225935 Subscriber 0x79 O.k.
- 0x30 1 0x2
528473275930 Publisher 0xd O.k.
528473325924 Subscriber 0x79 O.k.
* Error * - An unknown error occurred within the PLIN Device Manager.
Bus: Active
Bus: Active
Reset Client Done
Remove Client Done
Reset Client Done
Remove Client Done
Post by M.Heidemann » Mon 8. Apr 2024, 14:38
Did you ensure that you read the RcvQueue until empty? Otherwise the queue can fill up and timing can be thrown off.
You can use the TLINError-Return "errRcvQueueEmpt" as a condition on read, to ensure the queue is properly emptied upon reading.
Please see PLIN-API docs chapter 4.4.10 "LIN_Read" regarding this.
As long as reading does not return "errRcvQueueEmpt", there are still messages to be read in queue.
luciangu
Re: PLIN API on Python 3.11.4: Read queue delays
Post by luciangu » Tue 9. Apr 2024, 14:35
Thanks for the advice. I thought that by sending frames in the schedule table, periodically, the queue will never be empty. I've tried with read until TLIN_ERROR_RCVQUEUE_EMPTY and it's ok now, but I need a small delay (0.2-0.3 seconds) between updating data on a node and read on the other node, which is ok.
My question now is how I can get the timestamps and compare them to be sure that the data is updated and received by the other node in the specified timestamp? I saw that the timestamp read on TLINRcvMsg is different than the one from the one returned by GetTargetTime.
Thanks!
Lucian
Post by M.Heidemann » Tue 9. Apr 2024, 16:08
The timestamp will represent the time at which the frame was pushed to the bus.
GetSystemTime yields the time-base currently used by the hardware (Aka the time since Hardware recognition based on SystemTime)
Timestamps are the accurate way to represent frame-timings, GetSystemTime is
intended to be used to provide context to the timestamps you are getting, not
to replace them.
If you don't receive any errors back you can assume that the messages are properly pushed
to the bus. If you want to get the timeframe of message reception, you will have to handle that
at reception side.
