Reading latest signal-values by macro
mulan_nl
Post by mulan_nl » Thu 14. Mar 2013, 16:59
Currently, I am reading the latest message value by using:
signal_name.MessageToValue(msgs(msgs.Count-1))
which parses through the entire received messages buffer, which is quite slow.
1. Is there another way (macro?) to receive the latest message signal information only?
I am using Set msgs = trc.Messages.FindSymbol(sym) to link the new messages each time. (this could may be the cause of the delays)
2. Is it also possible during 'live' mode, i.e. when a connection is made using Connections.ReceiveMessages?
Re: Reading latest signal-values by macro
Post by PEAK-Support » Fri 15. Mar 2013, 09:51
When you work with Signals, you do not need to iterate to the Message queu. The Signal will always have the lates value. Means, if your Signal is defined as a Bitsection of a incomming CAN Frame, you only need to read the Signal.Value and you have the latest value. Attached a simple project that use a Symbol File that define 2 Signals based on a CAN Frame and use them to calculate a third, virtual, Signal.
Power.zip
power calculating sample project for PE5
(3.73 KiB) Downloaded 441 times
