PCAN_ERROR_INITIALIZE
I'm currently able to Initialize CAN with python (script 1), but my target is to be able to read the messages written by the script 1 with another independently script 2 in the same computer but when I try to Initialize the Peak with this second script it gives me the error (Indicates that the desired PCAN Channel cannot be connected because it is already in use (PCAN-Basic / PCAN-Light environment)). I don't know if it is possible to do what I am trying to do but, for example, PCAN-View is able to do it.
Re: PCAN_ERROR_INITIALIZE
Just randomly copying and pasting code will not really yield the results you want to achieve,
once a channel is initialized, it is given a handle.
What you are trying to do would require a second PCAN-Interface that will read the messages,
in this case you will need to change the TPCAN_Handle. If you want to keep track of the messages
sent out on the same interface, you will have to handle it within the application itself.
If you want to simply access an already initialized handle by another application, you don't need to initialize it again.
Please read the documentation thoroughly.
I already read the documentation. Firstly I didn’t tried to initialize the channel, but when I wanted to acces to this cannel with the same TPCANHandle as it is initialized firstly it returns that this channel wasn’t initialize yet and can’t read the messages.
I can share the code used if it can be usefull.
Please do, maybe i can be of more help to you when i see
what exactly you are trying to do.
This are the two codes, the sender is the first initialized and the reciver the second one, without initializing the peak, only looking for the chanel where is the specified Peak ID.
Sender
Reciver
Sender
import cantools
import time
import ctypes
from PCANBasic import *
class DEVICE:
def __init__(self):
self.db = cantools.database.load_file('DBC.dbc')
self.id = [message.frame_id for message in self.db.messages]
self.channel = PCAN_USBBUS1
self.baudrate = PCAN_BAUD_500K
self.h = PCANBasic()
self.DEVICE_ID = 0x4
channel = self.h.LookUpChannel(b"devicetype=pcan_usb, deviceid=0x4")
if channel[0] != PCAN_ERROR_OK:
result = self.h.GetErrorText(channel[0])
print (result[1])
else:
if channel[1].value != PCAN_NONEBUS.value:
print (f"The channel handle for the PCAN-USB with ID={self.DEVICE_ID} was found")
self.channel = channel[1]
else:
print (f"A PCAN-USB device with ID={self.DEVICE_ID} is not available")
print(self.channel)
result = self.h.Initialize(self.channel, self.baudrate)
self.data = {}
if result != PCAN_ERROR_OK:
print(f"Error initializing CAN channel: {result}")
exit(1)
else:
print(f"Initialized CAN channel: OK")
if self.h == None:
exit(1)
self.time = time.time()
self.msg = TPCANMsg()
self.msg.ID = 0x5BF
self.msg.LEN = 8
self.msg.DATA = (0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11)
def send_can_message(self,info):
result = self.h.Write(self.channel, info)
MFL = DEVICE()
while True:
MFL.send_can_message(MFL.msg)
time.sleep(0.5)
import cantools
import time
import ctypes
class DEVICE:
def __init__(self):
print (result[1])
else:
else:
# result = self.h.Initialize(self.channel, self.baudrate)
self.data = {}
print(self.channel)
# if result == PCAN_ERROR_INITIALIZE:
# print(f"CAN {self.DEVICE_ID} already initialized")
# elif result != PCAN_ERROR_OK:
# print(f"Error initializing CAN channel: {result}")
# exit(1)
# else:
# print(f"Initialized CAN channel: OK")
if self.h == None:
exit(1)
self.msg.ID = 0x5BD
self.msg.LEN = 4
def receive_can_message(self, ID = None):
# Receive a CAN message
result, msg_recived, time = self.h.Read(self.channel)
if result == PCAN_ERROR_OK:
pass
elif result == PCAN_ERROR_QRCVEMPTY:
print('None')
return True
else:
print(f"Error receiving CAN FF message: {result}")
return True
if ID != None:
while ID != msg_recived.ID:
return True
if msg_recived.ID in self.id:
info = self.db.decode_message(msg_recived.ID, bytes(msg_recived.DATA), decode_choices=False)
self.data[msg_recived.ID] = info
print(result)
MFL = DEVICE()
while True:
# MFL.send_can_message(MFL.msg)
MFL.receive_can_message()
time.sleep(0.5)
I understand, no that's not possible. PCANBasic can only access the initialized channel
within the application that initialized it. My previous answer was a bit misleading, as
i wrote "application", i was refering to other functions within the same application, my bad.
In your case, you will have to bring both Tx and Rx into the same application in order for it to work in PCANBasic.
