dtran
Post
by dtran » Thu 18. Apr 2024, 01:06
I am running into an issue in PCAN-Explorer 5.3.4 that is very similar to the issue reported on this thread:
viewtopic.php?t=2984. I cannot update to PCAN-Explorer 5.4 since I need the instrument panel option (got a message stating instrument panel requires 5.3).
When I run the sample script called "NewClientSend" my PCAN-Explorer would abruptly exit. This test is to rule out my script.
In my VBS script, I have determined that the following code will cause the script to terminate:
Dim client
MsgBox "Here!"
Set client = CreateObject("PCAN3.PCANClient")
MsgBox "Won't reach here!"
Warning Message:
- PCAN Warning .png (9.44 KiB) Viewed 2222 times
Any suggestions on how I can fix this without upgrading my PCAN-Explorer?
- Support
Post
by M.Maidhof » Thu 18. Apr 2024, 14:12
please send an email to our support email address with your license ID of your PCAN-Explorer 5 and your project files, to be able to check the issue.
best regards
dtran
Post
by dtran » Fri 19. Apr 2024, 18:01
Thank you, Michael. I have sent you the email with the information requested.
Post
by M.Heidemann » Mon 22. Apr 2024, 08:50
Support provided via email.
- closed -
