Hello all,
Is it possible to configure on a MicroMod FD module a CRC16 algorithm on a CAN signal, using the PCAN-MicroMod FD Configuration tool?
I cannot find anything about this in the documentation and nothing similar seems to be available in the tool (at 'Transmit Symbols' configuration).
CRC algorithm with PCAN-MicroMod FD Configuration tool?
Re: CRC algorithm with PCAN-MicroMod FD Configuration tool?
for this kind of application you have to write an own firmware for the PCAN-MicroMod FD using the compiler and examples from the PEAK-Dev pack. The standard fimrware and the Configuration tool doesn't offer this option at the moment.
Thank you for your reply.
I will give it a try.
Could you offer guidance on writing custom firmware for the PCAN-MicroMod FD using the compiler and examples from the PEAK-Dev pack?
Did you check the readme file inside the devpack?
Besides listing the contents there is a dscription as to how to use the Devpack
BR
BR
Check the examples provided in the pack for PCAN-MicroMod_FD, they cover an extensive range of topics.cornypolard wrote: ↑Fri 31. May 2024, 06:52Could you offer guidance on writing custom firmware for the PCAN-MicroMod FD using the compiler and examples from the PEAK-Dev pack?
Make sure you have installed Visual Studio Code and follow the steps in ReadMe.txt file.
I managed to implement the features I was looking for without any problems.
Thank you for your information!Adrian wrote: ↑Mon 3. Jun 2024, 08:13Check the examples provided in the pack for PCAN-MicroMod_FD, they cover an extensive range of topics.cornypolard wrote: ↑Fri 31. May 2024, 06:52Could you offer guidance on writing custom firmware for the PCAN-MicroMod FD using the compiler and examples from the PEAK-Dev pack? hill climb racing
