minimum Separation Time minimum (STmin ) between two consecutive frames?
sandeepc
Post by sandeepc » Thu 9. May 2024, 13:05
We are using PEAK CAN ISO TP standard library to send binary file from PC to MCU.
I can able to send and receive frame between the MCU and PC(visual studio code) with delay between two consecutives fames is 60ms(STmin ).
If i reduce to less than 60ms it will work few times only.
What is the minimum STmin time we can use between two consecutive frame.?
Is there any time restrictions are the in the PEAK CAN ISO TP of free version?
Sandeep C
Re: minimum Separation Time minimum (STmin ) between two consecutive frames?
Post by PEAK-Support » Fri 10. May 2024, 10:11
No restriction - have you checked how long your MCU needs to response?
