Source and Target address
sandeepc
Post by sandeepc » Thu 16. May 2024, 14:23
I can able to receive and transmit the frame, through callback function.
But when i try to read the data from ECU i could not able to read the same data in polling method.
CAN ISO TP configuration:
uint32_t ISOTP_init(cantp_mapping *mapping, cantp_handle client_handle, cantp_msg *tx_msg, cantp_msg* crc_msg)
	char version_buffer[500];
	cantp_status res;
	// Print version informations
	CANTP_GetValue_2016(PCANTP_HANDLE_NONEBUS, PCANTP_PARAMETER_API_VERSION, version_buffer, 500);
	printf("PCAN-ISO-TP API Version: %s\n\r", version_buffer);
	// Initialize channels: CAN2.0 - 500Kbit/s
	res = CANTP_Initialize_2016(client_handle, PCANTP_BAUDRATE_125K, (cantp_hwtype)0, 0, 0);
	printf("Initialize: %s\n", STATUS_OK_KO(res));
	// Change STmin value to 600us
	// Allocate tx message
	res = CANTP_MsgDataAlloc_2016(tx_msg, PCANTP_MSGTYPE_ISOTP);
	printf("Allocate tx message: %s\n\r", STATUS_OK_KO(res));
	res = CANTP_MsgDataAlloc_2016(crc_msg, PCANTP_MSGTYPE_ISOTP);
	printf("Allocate crc_msg message: %s\n\r", STATUS_OK_KO(res));
	// Set priority (add message options)
	res = CANTP_MsgDataInitOptions_2016(tx_msg, 1);
	tx_msg->msgdata.any->options->buffer[0].name = PCANTP_OPTION_J1939_PRIORITY;
	tx_msg->msgdata.any->options->buffer[0].value = 0x02;
	printf("Set message priority option: %s\n\r", STATUS_OK_KO(res));
	res = CANTP_MsgDataInitOptions_2016(crc_msg, 1);
	crc_msg->msgdata.any->options->buffer[0].name = PCANTP_OPTION_J1939_PRIORITY;
	crc_msg->msgdata.any->options->buffer[0].value = 0x02;
	// Create a simple physical mapping:
	//    - Source 0xF1 (client), target 0x01 (server)
	//    - Diagnostic message in a fixed normal format
	mapping->can_msgtype = PCANTP_CAN_MSGTYPE_EXTENDED;
	mapping->netaddrinfo.extension_addr = 0x00;
	mapping->netaddrinfo.format = PCANTP_ISOTP_FORMAT_FIXED_NORMAL;
	mapping->netaddrinfo.msgtype = PCANTP_ISOTP_MSGTYPE_DIAGNOSTIC;
	mapping->netaddrinfo.source_addr = 0xF1;
	mapping->netaddrinfo.target_addr = 0x01;
	mapping->netaddrinfo.target_type = PCANTP_ISOTP_ADDRESSING_PHYSICAL;
	printf("Can tp initialze success\n\r");
	return 1;
ECU configuration:
n_req_t dummy_frame =
	.n_ai.n_pr = 0x08,                            /* Network Address Priority */
	.n_ai.n_sa = 0xF1,                           /* Network Source Address */
	.n_ai.n_ta = 0x01,                           /* Network Target Address */
	.n_ai.n_ae = 0x00,                         /* Network Address Extension */
	.n_ai.n_tt = N_TA_T_PHY,             /* Network Target Address type */
	.fr_fmt = CBUS_FR_FRM_STD,        /* CANBus Frame format */
Is it above configuration is correct or is it required swap source and target address in ECU side to exchange source and target address?
can you elaborate on these configuration.
Sandeep C
Reason: added code formatting
F.Vergnaud
Re: Source and Target address
Post by F.Vergnaud » Thu 16. May 2024, 15:59
Mappings are not required when using format FIXED_NORMAL, see user manual p.263 §4.4 ISO-TP Network Addressing Format.
You should check sample 04_client_ISO15765-2_fixed_normal_addressing.
Fabrice
sandeepc
Post by sandeepc » Fri 17. May 2024, 10:40
Thanks for the reply,
Which addressing format is better to exchange data between pc and ECU?
Can you give an example for better mapping between ECU and PC?
sandeep C
F.Vergnaud
Post by F.Vergnaud » Fri 17. May 2024, 11:43
The choice of adressing format is out of scope of our API, this design process is based on multiple factors (support of 29 bit CAN ID or not, need to have the target address in the data content, etc.) and should be defined by the architect of the CAN/ISOTP network .
Check document ISO-15765-2 if you need to learn more about ISOTP network addressing.
The PCAN-ISO-TP package already includes examples with mappings like 01 and 02 or with automated mappings like 03 and 04.
Fabrice
