I'm new about peak products and I have a problem with the Analog1 - Micromod FD module:
I need to generate some CAN messages to convert analog signals into CAN Message so:
1: I enabled analog Inputs (16 bit)
2: I created Signals and I have associated each signal to one analog input
3: I Created a couple of symbols and I have associated the signals (variables containing signals) to the symbols
4: I sent configuration to the module by clicking on "Send Configuration". The configuration was transmitted successfully.
5: The activity LED is GREEN and blinking normally
6: I disconnected the PCAN-USB from software. Now the analog 1 module should work standing alone.
7: I opened PCAN-View
8: Connected PCAN-USB
9: Started the measure but...
Nothing in trace window.
Is anyone able to tell me where is my fault? (attached you will find the configuration)
Many thanks
Unable understanding if Analog1 module is working or not
- SchenckRig_2_Stations.zip
- Configuration
- (2.05 KiB) Downloaded 6631 times
Re: Unable understanding if Analog1 module is working or not
no idea, what´s wrong on your side but your config is working@500k. Maybe you don´t have transferred the config correctly into the module, or you have selected a wrong baudrate or your are using filters.
Many thanks I'll focus on connection parameters.
