Listen-Only mode on Linux stopped working
I've moved my setup to a new system and the Listen Only mode does not seem to work any more. I'm using Ubuntu 20.04 with peak-system USB adapter. The driver version is v8.18.0 and the PCAN-View version is v0.9.3-2-gd2f361a. Without Listen Only option the PCAN-View transmits and traces the messages on the bus, but if I set Listen Only (and use a different device to send the CAN messages) the trace window remains empty. If I use the Windows PCAN-View it works just fine.
Re: Listen-Only mode on Linux stopped working
I was not able to replicate this behavior on in my tests using pcan-linux 8.18 and PCAN-View 0.9.3-53-g5adad75. Please check if you can upgrade to the latest version of PCAN-View using the installation described here:
https://www.peak-system.com/fileadmin/m ... n-view.php
Can you show me the output for:
and
uname -a
dmesg
The PCAN-View I've installed from the provided link shows version 0.9.3-2-gd2f361a and not 0.9.3-53-g5adad75 (as in your post). Just to be sure I removed and reinstalled.
uname -a:
dcval@dcval-NT2-HP-Z4-G4-Workstation:~/Downloads$ uname -a
Linux dcval-NT2-HP-Z4-G4-Workstation 5.15.0-113-generic #123~20.04.1-Ubuntu SMP Wed Jun 12 17:33:13 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
dmesg:
Attached.
Freddy
uname -a:
dmesg:
Attached.
Freddy
dmesg.txt
- (107.18 KiB) Downloaded 4690 times
- Support
From what i can see in your logs:
You are using the wrong driver variant, seems like you installed the NETDEV driver which is compatible with SocketCAN applications but not PCANView.
To confirm:
Switch to your peak-driver directory:
Afterwards check PCANView again.
BR
To confirm:
sudo make uninstall
make clean
make
sudo make install
sudo modprobe pcan
BR
Thanks, it works!
Freddy
Freddy
Thanks for the feedback!
- Topic closed -
- Topic closed -
