Hardware:
PLIN-USB, PC
Software:
PEAK software downloaded within past week. PLIN_API_Console.py is internally dated 09.11.2015
Python 3.10, Win10
Goal:
Control several PLIN-BUS in production setting to test functionality of manufactured pump product at various stages of build. Using Python with variety of meters, sensors etc.
Try:
PLIN-View PRO
Set connection as master. Controlling simple pump with only 2 valid LIN frames, one as publisher (cmd speed), the other subscribe the resulting data.
Setup with known LDF file
Everything works perfectly, very clear, very nice. Great simple program! I can switch the USB ports, power up/down the PLIN-Bus, never fails.
PLIN_API_Console.py
Running program as intended, tried both from IDLE or directly.
1. If PLIN-View PRO was run earlier in session, the API_Console.py works fine, and correctly identifies my 2 valid frames, no issues.
However.
2. if I switch USB ports, or power down the PC, or turn off power to the PLIN-USB, the API_Console.py might not connect properly. Does NOT identify valid publisher frame. CANNOT command speed. API_Console.py does NOT ask for frame data, as it does in 1. above. I can however see the subscriber frame correctly.
3. I then modify the API_Console.py, add various delays within the initialize() methos, using typical Python time.sleep(). Still variable success as in 2. above
So it seems the PLIN-View PRO has slightly more robust connection protocol than the API_Console.py Makes sense, the API_Console is now getting old. Any idea what API commands might help?
Andy
Different connection results: PLIN-View PRO vs. PLIN_API_Console.py
Re: Different connection results: PLIN-View PRO vs. PLIN_API_Console.py
this looks like the frame configuration in the hardware is not set correctly. When using PLIN-View Pro and you load a ldf file, the frame configuration listed in the ldf file is loaded into the PLIN hardware. If you use the PLIN_API_Console.py application without modification, the frame configuration is only set for some frames (0x1, 0x2, 0x3, 0x5, 0x3C, 0x3D) to a specific value. Did you adapt the frame config to your needed configuration in the python code?
No. I am ignorant, a very new LIN student, and did not. I see I need to change the code in the API_Console.py here, code lines 233-239:
The above code must be changed to match my two frames which are only 0x0A and 0x0B. These frames each have eight bytes each, and code must be something like
Not asking you to write my code, and thanks for your assistance
Andy
# length values is set to LIN 1.2.
if ((i >= 0x00) and (i <= 0x1F)):
lFrameEntry.Length = c_ubyte(2)
elif ((i >= 0x20) and (i <= 0x2F)):
lFrameEntry.Length = c_ubyte(4)
elif ((i >= 0x30) and (i <= 0x3F)):
lFrameEntry.Length = c_ubyte(8)
if i >= 0x0A and i <= 0x0B :
Andy
Also added these lines
if i == 0x0a :
lFrameEntry.Direction = PLinApi.TLIN_DIRECTION_PUBLISHER
lFrameEntry.ChecksumType = PLinApi.TLIN_CHECKSUMTYPE_CLASSIC
Hi Andy,
yes, you also have to set the checksum type depending on the configuration which is listed in the ldf. If you still have problems, send us the ldf to our support email address to be able to solve your problem.
