Error sending messages
USB to CAN Interface
financecajole
Post by financecajole » Thu 3. Oct 2024, 05:00
Hi i'm a new member
My CAN system works really well, and occasionally there are no errors at all, but other times there may be errors within a few minutes. Though my CAN stops sending messages and gives me a retry error (firmware retry), PCAN is not displaying any errors. Additionally, it is noted that when the listen-only mode is turned off, the error rate increases (ack error). For what reason is that the case? What is wrong with PCAN participating in the network?
Re: Error sending messages
Post by PEAK-Support » Thu 3. Oct 2024, 08:24
Looks like the Bitrate does not fit 100% or a missing termination etc.
Please check the CAN Basics first. You also could use the PCAN-View Tracer and switch on the logging of Error and Status Frames to see what exact happened on the Bus.
financecajole
Post by financecajole » Fri 4. Oct 2024, 03:13
Ok, let me check. Thanksslice master for your support.
