I need your advice for my application using PCAN-Router FD.
1. CAN2 is fixed setting as CAN 500K (#define _80M_500K_80____2M_80_ISO_NEW { CAN_CLOCK_80M, 4, 31, 8, 8, 96, 0, 1, 4, 7, 2, 2})
2. CAN1 is two kind of setting as CAN-FD (1) #define _80M_500K_80____2M_80_ISO_CANFD {CAN_CLOCK_80M, 2, 63, 16, 15, 96, 0, 1, 2, 15, 4, 4}
(2) #define _80M_500K_70____2M_75_ISO { CAN_CLOCK_80M, 2, 55, 24, 2, 96, 0, 1, 2, 14, 5, 5}
My intention is that change CAN1 setting as (1) or (2) via CAN2 message by another device.
If I send message of ID 0x771 via CAN2, CAN1 change to setting as (1).
If I send message of ID 0x772 via CAN2, CAN1 change to setting as (2).
I cannot sure it is possible or Not. Can you advice to me?
Change of Can FD timing
Re: Change of Can FD timing
yes, this is possible. You can change the CAN initialization during normal operation by calling:
CAN_UnInitialize ( CANHandle_t hBus);
followed by
CAN_Initialize ( CANHandle_t hBus, const CANTiming_t *timing);
with the new settings for your CAN channel. Please see \inc\can.h for more details about the API for the PCAN-Router FD
followed by
I would ask more one question.
CAN1 can be Initialized as Variables Not Const? I want change CAN timing parameters by external command via CAN2.
- CAN_Initialize ( CANHandle_t hBus, const CANTiming_t *timing); --> CAN_Initialize ( CANHandle_t hBus, CANTiming_t *timing); ??
if it is possible, pls let me know the solution.
yes, also possible. Your variable must be of type CANTiming_t than:
typedef struct {
uint32_t can_clk; //!< clock for CAN controller, see CAN_CLOCK_...
uint16_t nom_brp; //!< prescaler for arbitration phase ( 1..1024)
uint16_t nom_tseg1; //!< Tseg1 for arbitration phase ( 1..256)
uint8_t nom_tseg2; //!< Tseg2 for arbitration phase ( 1..128)
uint8_t nom_sjw; //!< SJW for arbitration phase ( 1..128)
uint8_t warning_limit; //!< error warning limit ( ewl typical 96)
uint8_t listen_only; //!< 0=normal, 1=listen only mode
uint8_t can_mode; //!< 0=CAN-FD nonISO, 1=CAN-FD ISO, 2=CAN_20_AB (forced)
uint16_t data_brp; //!< prescaler for CAN-FD data phase ( 1..1024)
uint8_t data_tseg1; //!< Tseg1 for CAN-FD data phase ( 1..32)
uint8_t data_tseg2; //!< Tseg2 for CAN-FD data phase ( 1..16)
uint8_t data_sjw; //!< SJW for CAN-FD data phase ( 1..16)
} CANTiming_t;
