I am using PLIN USB and PLIN View Pro software.
My LDF has a Schedule Table which is loaded and running correctly.
I want to stop the Schedule Table through the commands, is it possible to stop the running Schedule table through master 3C ?
or how can we stop in other ways than manually?
How to stop Schedule Table through command.
Re: How to stop Schedule Table through command.
you can run a VBscript to start and stop a scheduler in PLIN-View Pro. See Help->VBScript Support for more details. But it is not possible to stop the scheduler by LIN data with PLIN-View Pro. For such an use case you have to write an own application using the PLIN-API.
