What is the benefit of using Signals vs. Variables?
rrmueller
Post by rrmueller » Tue 11. Feb 2025, 19:52
I am curious on what is preferred when creating symbol files for my PCAN Explorer projects. What are the reasons for having two different methods? In my current usage, I prefer variables, as I believe it keeps the symbol file cleaner, however the help docs do not describe a preference or differences between the two.
Thank you,
rrmueller
Re: What is the benefit of using Signals vs. Variables?
Post by M.Heidemann » Wed 12. Feb 2025, 07:52
Check the help under "Automating tasks with PCAN-Explorer" -> Objects.
Signals and variables are different in purpose:
A variable is ALWAYS bound to a real CAN-message,
Signals CAN be but also can be unassigned.
Also they do have differing parameters.
BR
rrmueller
Post by rrmueller » Wed 12. Feb 2025, 14:28
Hi Marvin,
Thank you for the response. Would I be correct in saying that if you use a variable with the same name, it produces copies unique to the CAN message it's assigned to? And along the same line, assigning a signal in multiple CAN messages would only reference a signal instance/value?
It sounds like variables have more flexibility. Such as if you have a lot of CAN messages of the same type - for example, input/output pin diagnostics.
rrmueller
Post by M.Heidemann » Wed 12. Feb 2025, 14:34
That's pretty mch how they work yes, Signals are "global" and can exist in multiple different Symbols (Messages), Variables are not. They only exist in the scope of one message.
BR
