Using the PCAN Micromode PEAK MicroMod CANopenIA V1.01 Rev.208
Using CANopen Magic Ultimate.
Using the simple steps in the manual, I can not get it to work.
Writing NI55 to Object Dictionary entry [1F50h,03h], then reset does not change Node ID.
Saving the current configuration into non-volatile memory by writing “save” to OD entry Store Parameters [1010h,01h], or loading the default configuration by writing “load” to the OD entry Restore Parameters [1011h,01h] does not appear to work.
I am a beginner...
Cannot Change Node ID
Re: Cannot Change Node ID
have you try this: LINK
