Hi
I need to set CAN speed to 666.667 kbps, but enum 'Bitrate' (PCANBasic.NET assembly) hasn't that speed.
How can I set that speed?
Best regards
tomekk
Can speed 666.667 kbps
Re: Can speed 666.667 kbps
Hello Tomekk,
Which device do you currently use?
How to approach this is somewhat dependent on the used device.
BR
BR
I use both "PCAN-USB Pro FD" and "PCAN-USB FD"
The the easiest way is to use our Bitrate-Calculation Tool:
https://www.peak-system.com/Bit-Rate-Ca ... .html?&L=1
The bitrate (for Initialize() ) is given as a BTR0/BTR1 register code, use the "SJA1000" option in the Bitrate calculation tool.
BR
BR
It works
Thank you very much
tomekk
Thank you very much
tomekk
