get Results from SvcReadMemoryByAddress_2013
Rommel
Post by Rommel » Sun 2. Mar 2025, 23:35
Hi
I am struggling to extract the returned information
I checked the CAN comunication and it looks fine. THe UDS Message is send and the ECU Returns some values.
And API is returning StatusiO. But I do not get the retunred information back.
status = UDSApi.SvcReadMemoryByAddress_2013(tp_handle, config, out request, address_buffer,2, result_buffer,2);
if (UDSApi.StatusIsOk_2013(status))
status = UDSApi.WaitForService_2013(tp_handle, ref request, out response, out confirmation);
First I thougtht the answer is stored inside result_buffer or is it returned at responce ?
I checked your documenation, but this parameters are not 100% clear to me
thanks
F.Vergnaud
Re: get Results from SvcReadMemoryByAddress_2013
Post by F.Vergnaud » Mon 3. Mar 2025, 09:36
Your variable "result_buffer" is wrongly named: it is actually an input buffer for the size of the memory that you want to read in the UDS request.
Please note that those parameters are based on ISO 14229-1, you can check this standard if you want to learn more on UDS service ReadMemoryByAddress (23h).
All PCAN-UDS functions starting with Svc (for Service) only transmit a UDS request and the parameters are used to initialize that request.
The ECU's response is received and made available to the user via the WaitForService functions:
- Your variable "response" will be filled with the UDS response of the ECU that contains the memory data.
For function "UDS_SvcReadMemoryByAddress_2013", you can find a C/C++ sample in example "06_client_all_request", check function "testReadMemoryByAddress".
Fabrice
