Trouble with the integration of the library PCAN-UDS
Benoit_V
Post by Benoit_V » Fri 28. Feb 2025, 09:10
I have some trouble with the integration of the library PCAN-UDS.
In my use case, I need to commmunicate with my system with specific CAN Frame and I need UDS CAN too in the same time.
I use Qt5 for my application.
Sometimes, a multiframe UDS is not transmitted entirely.
For example, the service UDS_SvcRequestDownload_2013:
18DA01F1 8 10 0B 34 00 44 00 00 00 // Sent from my application
18DAF101 8 30 00 00 00 00 00 00 00 // Answer from my system (Acknowledge)
18DA01F1 8 21 01 00 00 00 A0 55 55 // End of multiframe.
18DAF101 8 03 74 10 82 00 00 00 00 // Continue the next step
In case all is OK:
0000F8FE 8 01 01 00 00 07 02 00 02 // Specific frame (not UDS)
000500FE 8 05 00 00 00 00 00 00 00 // Specific frame (not UDS)
000501FE 8 00 00 00 00 00 00 00 00 // Specific frame (not UDS)
18DAF101 8 03 74 10 82 00 00 00 00 // Continue the next step UDS
In case of trouble:
....... // Not end of multiframe
Do you have an idea what is the potential problem?
Best regards.
Re: Trouble with the integration of the library PCAN-UDS
Post by M.Maidhof » Tue 4. Mar 2025, 09:22
as a first step, please check that you use the latest available dll files for PCANBasic, PCAN-ISO-TP and PCAN-UDS. You can use the sysinfo tool to check your system, and send the result to our support email address so that we can have a look on your system:
https://www.peak-system.com/fileadmin/m ... ysInfo.zip
Do you call CAN_Read() from PCANBasic while you use the PCAN_UDS API?
