Plugins for Graphical analysis.
Windows® Compatible Software for Displaying LIN Messages
gagan.k
Post by gagan.k » Mon 7. Apr 2025, 15:11
Are there any plugins to enable graphical analysis in PLIN. How to add this feature.
Re: Plugins for Graphical analysis.
Post by M.Maidhof » Mon 7. Apr 2025, 16:17
PLIN-View pro don't offer any graphical analysis tools. But you can use the PLIN-API to build an own application to analyze the LIN bus in a graphical way.
gagan.k
Post by gagan.k » Tue 8. Apr 2025, 14:32
Hi Micheal,
Thanks for the reply.
Could you [pls give some more info on which PLIN-API, is it the one PLIN Example API that is been provided by the tool or need to build our own API. If this is the case could you pls provide the details and direction in order to proceed with graphical representation in PLIN view Pro.
Post by M.Maidhof » Tue 8. Apr 2025, 16:40
here the link to the PLIN-API: https://www.peak-system.com/fileadmin/m ... in-api.zip
the API itself don't offer any graphical display, it gives you access to the raw LIN data, which you can use in your application to display it in a graphical way.
