Dear,
I'm in the process of purchasing your CAN bus analyzer tool PCAN-USB.
It appears to be right what I'm needing.
However, one question where I cannot find the answer;
What is the max amount of transmit messages you can send from the User Interface scheduletable? Is there any limitation in this?
I would need to be able to send at least 10 different messages (repeated at 10mSec and/or only once).
Kind regards, Hein.
Max number of TX messages scheduled.
Re: Max number of TX messages scheduled.
with PCAN.View 3.x you can define up to 30 transmit messages in the transmit list, when you use an own application with our API or with PCAN-Explorer 5 there are no restrictions. Only the busload on your CAN system will be the limit than.
Ok, perfect.
Thanks for your reply.
Hein.
Hein.
