PCAN Dongle on Win 7
Parallel Port to CAN Interface
fakrul_anuar
Post by fakrul_anuar » Tue 22. Apr 2014, 04:37
Does PCAN Dongle support Windows 7? I am migrating a system from an existing Win XP to Win 7 so interested toknow if the device can still be use.
Thanks...
Re: PCAN Dongle on Win 7
Post by PEAK-Support » Tue 22. Apr 2014, 08:15
The PCAN-Dongle (parallel Port Interface for CAN) work fine under Windows Vista/W7/w8 32Bit. 64 Bit OS is not supported.
The PCAN-USB and all other PEAK PC CAN Interfaces work also fine on 64 Bit OS.
The latest drivers could be found in our Support Section - Donwload the package of your need (depending which CAN Interface you own ) and run the PeakOemDrv.exe Setup.
