Using the GATEWAY as aternative for CAN card.
CAN to LAN gateway in DIN rail plastic casing
reneeteunissen
Post by reneeteunissen » Wed 20. Aug 2014, 10:46
In the post http://www.peak-system.com/forum/viewto ... 158&t=1057 I read that the gatways can be controlled from within an PC application. We are wondering is we could replace CAN card wit a gateway and if there are pro's and cons we should think about.
We have a linux system and like to talk to the gateway and use it as a "remote" CAN card.
Kind Regards,
Renee Teunissen
S.Michaelsen
Hardware Development
Re: Using the GATEWAY as aternative for CAN card.
Post by S.Michaelsen » Wed 20. Aug 2014, 12:54
you could only receive and send CAN messages via network sockets but you could not change the settings of the gateway. You'd have to configure it via the web interface.
Best Regards,
Stephan Michaelsen
