post processing of CAN data
deardee
Post by deardee » Tue 14. Jun 2011, 11:33
Hi
I am currently receiving some raw data from a bus CAN.
I would like to perform some post processing on those data before posting them with a "Value Indicator".
I assume that I need to use a "virtual varialbe" and a "visual basic Macro" but I did not find the way to do it.
Would you have any example explaining the way to do it.
With regards.
Re: post processing of CAN data
Post by PEAK-Support » Tue 14. Jun 2011, 14:29
Here a simple sample of a VB-Script that use virtual Signals:
We have two real signals based on CAN Data using the ID 0x100.
The Voltage is an unsigend Interger using the first two Data Bytes, and the Ampere, also an unsigned Integer, using the Data Bytes 3 and 4. Inside the VBS Macro we use these two signals to calculate the power, and store the calculated value into a virtual Signal. This virtual Signal could than be used to send again on the CAN Bus, or could be used to show the calculated value inside the User Panel or the Watch Window.
FormatVersion=5.0 // Do not edit!
Title="power"
{SENDRECEIVE}
[Symbol]
ID=100h
DLC=8
Var=Voltage unsigned 0,16 /u:Volt /max:10000
Var=Current unsigned 16,16 /u:Ampere /max:500
Apply the Symbol file and start this Macro:
Sub CalculatePower()
  Dim voltage, current, power
  Set power = Signals("Power")
  If power Is Nothing Then
  End If
  While True
    Wait(10)	' Prevent 100% CPU load
  Wend
End Sub
