Problem with two PCAN-PCI express on the same CAN bus
PCI to CAN Interface
ttris
Post by ttris » Wed 11. Mar 2015, 10:10
Hi everyone,
Given the architecture of a system I am developing I need to use two computers equipped with a PCAN-PCI express board on the same CAN bus.
The system is functional and I can communicate with my devices but sometimes I get some CAN error (bus heavy mostly) and I need to reset the system to get rid of those.
So my question is : Is it possible to use two PCAN-PCI express boards on the same CAN bus, or is it forbidden?
Thanks in advance,
Kind regards
Re: Problem with two PCAN-PCI express on the same CAN bus
Post by M.Maidhof » Wed 11. Mar 2015, 13:35
yes of course you can use several PCAN-PCI Express cards on the same CAN bus system, but please take care that it is not allowed to send the same CAN IDs from different CAN nodes at the same time. This will cause an arbitration crash on the CAN system.
ttris
Post by ttris » Thu 12. Mar 2015, 11:53
Thanks a lot for the quick answer.
I'll check on other possible mistakes that could have been made.
Kind regards
Post by M.Maidhof » Thu 12. Mar 2015, 15:29
please check that you use a CAN cable with termination resistors on both ends.
best regards
