I'm trying to install the drivers on Ubuntu 14.04 with a Xenomai 2.6.4 patched 3.14.17 kernel. I'm using the two-channel PCI card.
It seems to build fine:
$ make clean
rm -f src/*o src/*~ src/.*cmd *o *ko *~ .*cmd pcan.mod.c
$ make RT=XENOMAI
*** Host machine kernel version=3.14.17-ap15.1215
*** Driver kernel version=3.14.17-ap17.1530
*** Path to kernel sources=/lib/modules/3.14.17-ap15.1215/build
*** use KBUILD=yes
--xeno-cflags is deprecated, use --skin=name --cflags instead
make -C /lib/modules/3.14.17-ap15.1215/build SUBDIRS=/home/benblumer/Desktop/peak-linux-driver-7.14/driver EXTRA_CFLAGS="-I/home/benblumer/Desktop/peak-linux-driver-7.14/driver -DNO_DEBUG -DMODVERSIONS -DPARPORT_SUBSYSTEM -DNO_USB_SUPPORT -DPCI_SUPPORT -DNO_PCIEC_SUPPORT -DISA_SUPPORT -DDONGLE_SUPPORT -DNO_PCCARD_SUPPORT -DNO_NETDEV_SUPPORT -DXENOMAI -I/usr/include/xenomai -D_GNU_SOURCE -D_REENTRANT -D__XENO__" V=0 modules
make[1]: Entering directory `/home/benblumer/xeno-install/linux-3.14.17'
CC [M] /home/benblumer/Desktop/peak-linux-driver-7.14/driver/src/pcan_main.o
CC [M] /home/benblumer/Desktop/peak-linux-driver-7.14/driver/src/pcan_fops.o
CC [M] /home/benblumer/Desktop/peak-linux-driver-7.14/driver/src/pcan_fifo.o
CC [M] /home/benblumer/Desktop/peak-linux-driver-7.14/driver/src/pcan_filter.o
CC [M] /home/benblumer/Desktop/peak-linux-driver-7.14/driver/src/pcan_parse.o
CC [M] /home/benblumer/Desktop/peak-linux-driver-7.14/driver/src/pcan_sja1000.o
/home/benblumer/Desktop/peak-linux-driver-7.14/driver/src/pcan_sja1000.c: In function ‘sja1000_irqhandler_common’:
/home/benblumer/Desktop/peak-linux-driver-7.14/driver/src/pcan_sja1000.c:696:2: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
struct can_frame ef;
CC [M] /home/benblumer/Desktop/peak-linux-driver-7.14/driver/src/pcan_common.o
CC [M] /home/benblumer/Desktop/peak-linux-driver-7.14/driver/src/pcan_pci.o
CC [M] /home/benblumer/Desktop/peak-linux-driver-7.14/driver/src/pcan_isa.o
CC [M] /home/benblumer/Desktop/peak-linux-driver-7.14/driver/src/pcan_dongle.o
LD [M] /home/benblumer/Desktop/peak-linux-driver-7.14/driver/pcan.o
Building modules, stage 2.
MODPOST 1 modules
CC /home/benblumer/Desktop/peak-linux-driver-7.14/driver/pcan.mod.o
LD [M] /home/benblumer/Desktop/peak-linux-driver-7.14/driver/pcan.ko
make[1]: Leaving directory `/home/benblumer/xeno-install/linux-3.14.17'
$ sudo make install
Info: /lib/modules/3.14.17-ap17.1530/misc exists.
$ sudo modprobe pcan
modprobe: ERROR: ../libkmod/libkmod-module.c:809 kmod_module_insert_module() could not find module by name='pcan'
modprobe: ERROR: could not insert 'pcan': Function not implemented
modprobe: ERROR: ../libkmod/libkmod-module.c:959 command_do() Error running install command for pcan
