Delete messages with a specific CAN-ID from Transmit List
jnota
Post by jnota » Mon 1. Jun 2015, 10:16
Hello everyone,
Does anyone knows how to delete messages with a specific CAN-ID from the Transmit List through VBS?
I don't want to clear all the Transmit List, just to erase some messages, according to their CAN-IDs...
Thanks in advance!
Re: Delete messages with a specific CAN-ID from Transmit Lis
Post by PEAK-Support » Mon 1. Jun 2015, 12:31
Here you find a simple Macro which generate 3 differnt CAN-ID´s in the Transmit List: ID 0x100, ID 0x110 and ID 0x120. Then the macro search in the Transmit List for the ID 0x100, ID 0x110 and ID0x120 and delete them.
Hope that solve your problem.
Option Explicit
Sub TransmitListSample_Start()
   Dim msg1, msg2, msg3
   ' generate 3 Messages and add to transmit List
   Set msg1 = Connections.TransmitMessages.Add
   ' Initialize the CAN message
   PrintToOutputWindow "Create 3 new Msgs in Transmit list - every Second a new one"
   With msg1
      .ID = &H100
      .DLC = 3
      .Data(0) = &H11
      .Data(1) = &H22
      .Data(2) = &H33
      .CycleTime =25
      If Connections.Count > 0 Then _
         Set .Connection = Connections(1)
   End With
   Wait(700) ' 700msec delay
   Set msg2 = Connections.TransmitMessages.Add
   With msg2
      .ID = &H110
      .DLC = 4
      .Data(0) = &H12
      .Data(1) = &H23
      .Data(2) = &H34
      .Data(3) = &H45
      .CycleTime =50
   End With
   Set msg3 = Connections.TransmitMessages.Add
   With msg3
      .ID = &H120
      .DLC = 8
      .Data(0) = &H1
      .Data(1) = &H2
      .Data(2) = &H3
      .Data(3) = &H4
      .Data(4) = &H5
      .Data(5) = &H6
      .Data(6) = &H7
      .Data(7) = &H8
      .CycleTime =100
   End With
   ' now search in the list for ID ßx100
   Set msg2 = Connections.TransmitMessages.FindID(&H100)
   MsgBox msg2.Count & " times CAN ID 0x100 found in Transmit List - now delete it"
   for each msg3 in msg2 ' search in thje collection of msg2 all IDs (msg3)
   	Connections.TransmitMessages.Remove msg3 ' and delet them
   next
   Wait(500)
   ' now search in the list for ID ßx110
   Set msg2 = Connections.TransmitMessages.FindID(&H110)
   MsgBox msg2.Count & " times CAN ID 0x110 found in Transmit List - now delete it"
   next
   Wait(500)
   ' now search in the list for ID ßx120
   Set msg2 = Connections.TransmitMessages.FindID(&H120)
   MsgBox msg2.Count & " times CAN ID 0x120 found in Transmit List - now delete it"
   next
End Sub
jnota
Post by jnota » Mon 1. Jun 2015, 13:14
U.Wilhelm wrote:Here you find a simple Macro which generate 3 differnt CAN-ID´s in the Transmit List: ID 0x100, ID 0x110 and ID 0x120. Then the macro search in the Transmit List for the ID 0x100, ID 0x110 and ID0x120 and delete them.
Option Explicit
   With msg1
      .ID = &H100
      .DLC = 3
      .Data(0) = &H11
      .Data(1) = &H22
      .Data(2) = &H33
      .CycleTime =25
   End With
   With msg2
      .ID = &H110
      .DLC = 4
      .Data(0) = &H12
      .Data(1) = &H23
      .Data(2) = &H34
      .Data(3) = &H45
      .CycleTime =50
   End With
   With msg3
      .ID = &H120
      .DLC = 8
      .Data(0) = &H1
      .Data(1) = &H2
      .Data(2) = &H3
      .Data(3) = &H4
      .Data(4) = &H5
      .Data(5) = &H6
      .Data(6) = &H7
      .Data(7) = &H8
      .CycleTime =100
   End With
   next
   Wait(500)
   next
   Wait(500)
   next
End Sub
Thank you U.Wilhelm! It works like a charm! :)
