Physically setting USB BUS
USB to CAN Interface
abhishek1808
Post by abhishek1808 » Thu 4. Jun 2015, 12:04
Hello
I observed that, when using the API the first USB interface which is connected to the PC in time is considered as USBBUS1 (Channel) and so on.... Is there a possibility that we set the USBBUS (handel) physically using device manager or some other solution. Basically I want to fix the physical USB port saying that this is USBBUS1 and when ever I connect the interface in Time that remains the USBBUS1. I am new to this so pardon if its a silly question.
Abhishek
Re: Physically setting USB BUS
Post by PEAK-Support » Thu 4. Jun 2015, 12:49
Please read here
abhishek1808
Post by abhishek1808 » Thu 4. Jun 2015, 16:02
Hello
The solution you provide fixes a particular interface to a particular application, the solution I am looking is to fix the USB Port on my laptop to that Specific Application irrespective of device ID used.
Is that possible. Please let me know
Abhishek
Post by K.Wagner » Thu 4. Jun 2015, 16:13
What you want to do is to fix a PCAN-Channel to a respective USB port of a computer. This is not possible. You can only fix a respective PCAN-USB device to a PCAN-Basic channel, for instance, that the PCAN-USB with ID 3 is always the channel USBBUS1.
abhishek1808
Post by abhishek1808 » Thu 4. Jun 2015, 16:58
Thanks for your answer, I shall find a work around
