Combining Signals
ldbrown
Combining Signals
Post by ldbrown » Wed 10. Aug 2011, 16:41
Hi
Is it possible to combine multiple signals?
For example: I have a signal for Voltage and a signal for Current and I would like to combine these two to give Power.
Is this possible?
If not is there another way in which I could produce a Power signal from the voltage and current messages?
ldbrown
Re: Combining Signals
Post by M.Maidhof » Fri 12. Aug 2011, 12:09
yes thats possible with the help of a VBmacro. Here is an example:
Sub CalculatePower()
Dim voltage, current, power
Set power = Signals("Power")
If power Is Nothing Then
End If
While True
Wend
End Sub
best regards
