Running macros simultaneously
Philipp
Post by Philipp » Fri 12. Aug 2011, 10:37
currently I'm testeing the trial version and I can't get macros to run simultaneously. I have tested each macro and all are functional. So I am wondering whether this is a limitation of the trial version.
Furthermore, I have problems deleting macro entries from the Project Explorer. Under Project Items there is a list of macros that I can't remove as the Remove button is deactivated and there is no context menu entry for deletion either. I can remove the macro files listed under Project Files, but that doesn't remove those macros form Project Items.
Is there a solution for these problems.
Best regards.
Re: Running macros simultaneously
Post by M.Maidhof » Fri 12. Aug 2011, 12:28
in one instance of PCAN-Explorer only one macro can run at the same time. To start several macros you have to start another instance of PCAN-Explorer.
When you have removed the files under Project Files, the Project Items will also be removed, you have to press F5 to update the Project Item view. Than the item will no longer be listed.
best regards
