PCAN-RS-232 open CAN port hangs the CAN bus
Programmable Converter for RS-232 to CAN
chuinfong
Post by chuinfong » Mon 16. Nov 2015, 03:21
Currently I am trying to use PCAN-RS-232 to tap into NMEA2000 CAN bus. The PCAN-RS-232 I am using is running using the default firmware came with the device. By using the Terminal commands, I am able to retrieve the CAN messages from the RS-232 port. However, occasionally (especially when I sent the command slowly, i.e. long interval between terminal commands), I receive no data from the RS232. Further probing on the CAN bus shows no activities (I have a NMEA device that constantly sending NMEA packet every 100ms). I noticed when I send command O<CR> to PCAN-RS232, the CAN bus activities suddenly just stopped (I probe the CAN bus using oscilloscope).
Here are the commands I used:
16/11/2015 10:57:31.150 [TX] - C<CR>
16/11/2015 10:57:31.152 [RX] - <CR>
16/11/2015 10:57:34.878 [TX] - S5<CR>
16/11/2015 10:57:34.883 [RX] - <CR>
<CR>
16/11/2015 10:57:41.054 [TX] - X1<CR>
16/11/2015 10:57:41.055 [RX] - <CR>
16/11/2015 10:57:42.589 [TX] - O<CR>
16/11/2015 10:57:42.591 [RX] - <CR>
T18EEFFFE8BD5865E72C96A0C0938A<CR>
16/11/2015 10:58:42.544 [TX] - F<CR>
16/11/2015 10:58:42.545 [RX] - F00<CR>
16/11/2015 10:58:49.753 [TX] - F<CR>
16/11/2015 10:58:49.755 [RX] - F00<CR>
16/11/2015 10:59:56.094 [TX] - C<CR>
16/11/2015 10:59:56.095 [RX] - <CR>
16/11/2015 10:59:56.805 [TX] - S5<CR>
16/11/2015 10:59:56.811 [RX] - <CR>
<CR>
16/11/2015 10:59:57.398 [TX] - X1<CR>
16/11/2015 10:59:57.399 [RX] - <CR>
16/11/2015 10:59:57.766 [TX] - e1<CR>
16/11/2015 10:59:57.770 [RX] - <CR>
16/11/2015 10:59:59.230 [TX] - C<CR>
16/11/2015 10:59:59.231 [RX] - <BEL>
16/11/2015 10:59:59.597 [TX] - S5<CR>
16/11/2015 10:59:59.603 [RX] - <CR>
<CR>
16/11/2015 11:00:00.029 [TX] - X1<CR>
16/11/2015 11:00:00.031 [RX] - <CR>
16/11/2015 11:00:00.405 [TX] - O<CR>
16/11/2015 11:00:00.407 [RX] - <CR>
16/11/2015 11:00:02.342 [TX] - O<CR>
16/11/2015 11:00:02.343 [RX] - <BEL>
16/11/2015 11:00:03.373 [TX] - C<CR>
16/11/2015 11:00:03.375 [RX] - <CR>
16/11/2015 11:00:04.517 [TX] - O<CR>
16/11/2015 11:00:04.519 [RX] - <CR>
16/11/2015 11:00:06.230 [TX] - C<CR>
16/11/2015 11:00:06.231 [RX] - <CR>
16/11/2015 11:00:07.046 [TX] - O<CR>
16/11/2015 11:00:07.047 [RX] - <CR>
16/11/2015 11:04:31.446 [RX] - <CR>
16/11/2015 11:04:32.948 [RX] - <CR>
16/11/2015 11:04:35.206 [TX] - C<CR>
16/11/2015 11:04:35.208 [RX] - <BEL>
16/11/2015 11:04:35.799 [TX] - S5<CR>
16/11/2015 11:04:35.804 [RX] - <CR>
<CR>
16/11/2015 11:04:36.319 [TX] - X1<CR>
16/11/2015 11:04:36.320 [RX] - <CR>
16/11/2015 11:04:36.750 [TX] - O<CR>
16/11/2015 11:04:36.752 [RX] - <CR>
T18EEFF6E8BD5865E72C96A0C00F79<CR>
T09FD026E80000008F74FAFFFF10AD<CR>
T09FD026E80000008F74FAFFFF1110<CR>
T09FD026E80000008F74FAFFFF1173<CR>
T09FD026E80000008F74FAFFFF11D7<CR>
T09FD026E80000008F74FAFFFF123A<CR>
16/11/2015 11:04:37.752 [RX] - T09FD026E80000008F74FAFFFF129E<CR>
T09FD026E80000008F74FAFFFF1301<CR>
T09FD026E80000008F74FAFFFF1364<CR>
T09FD026E80000008F74FAFFFF13C8<CR>
T09FD026E80000008F74FAFFFF142B<CR>
T09FD026E80000008F74FAFFFF148E<CR>
T09FD026E80000008F74FAFFFF14F2<CR>
T09FD026E80000008F74FAFFFF1555<CR>
T09FD026E80000008F74FAFFFF15B8<CR>
T09FD026E80000008F74FAFFFF161C<CR>
16/11/2015 11:04:38.752 [RX] - T09FD026E80000008F74FAFFFF167F<CR>
T09FD026E80000008F74FAFFFF16E2<CR>
T09FD026E80000008F74FAFFFF1746<CR>
T09FD026E80000008F74FAFFFF17A9<CR>
T09FD026E80000008F74FAFFFF180C<CR>
T09FD026E80000008F74FAFFFF1870<CR>
T09FD026E80000008F74FAFFFF18D3<CR>
T09FD026E80000008F74FAFFFF1936<CR>
T09FD026E80000008F74FAFFFF199A<CR>
T09FD026E80000008F74FAFFFF19FD<CR>
16/11/2015 11:04:39.752 [RX] - T09FD026E80000008F74FAFFFF1A61<CR>
T09FD026E80000008F74FAFFFF1AC4<CR>
T09FD026E80000008F74FAFFFF1B27<CR>
T09FD026E80000008F74FAFFFF1B8B<CR>
T09FD026E80000008F74FAFFFF1BEE<CR>
T09FD026E80000008F74FAFFFF1C51<CR>
T09FD026E80000008F74FAFFFF1CB5<CR>
T09FD026E80000008F74FAFFFF1D18<CR>
T09FD026E80000008F74FAFFFF1D7B<CR>
T09FD026E80000008F74FAFFFF1DDF<CR>
16/11/2015 11:04:40.752 [RX] - T09FD026E80000008F74FAFFFF1E42<CR>
T09FD026E80000008F74FAFFFF1EA5<CR>
T09FD026E80000008F74FAFFFF1F09<CR>
T09FD026E80000008F74FAFFFF1F6C<CR>
T09FD026E80000008F74FAFFFF1FCF<CR>
T09FD026E80000008F74FAFFFF2033<CR>
T09FD026E80000008F74FAFFFF2096<CR>
T09FD026E80000008F74FAFFFF20F9<CR>
T09FD026E80000008F74FAFFFF215D<CR>
T09FD026E80000008F74FAFFFF21C0<CR>
16/11/2015 11:04:41.752 [RX] - T09FD026E80000008F74FAFFFF2223<CR>
T09FD026E80000008F74FAFFFF2287<CR>
T09FD026E80000008F74FAFFFF22EA<CR>
T09FD026E80000008F74FAFFFF234E<CR>
T09FD026E80000008F74FAFFFF23B1<CR>
T09FD026E80000008F74FAFFFF2414<CR>
T09FD026E80000008F74FAFFFF2478<CR>
T09FD026E80000008F74FAFFFF24DB<CR>
T09FD026E80000008F74FAFFFF253E<CR>
T09FD026E80000008F74FAFFFF25A2<CR>
16/11/2015 11:04:42.752 [RX] - T09FD026E80000008F74FAFFFF2605<CR>
T09FD026E80000008F74FAFFFF2668<CR>
T09FD026E80000008F74FAFFFF26CC<CR>
16/11/2015 11:04:48.133 [RX] - <CR>
16/11/2015 11:04:49.635 [RX] - <CR>
16/11/2015 11:04:49.886 [TX] - O<CR>
16/11/2015 11:04:49.887 [RX] - <CR>
T18EEFF6E8BD5865E72C96A0C001C2<CR>
T09FD026E80000008F74FAFFFF02BB<CR>
T09FD026E80000008F74FAFFFF031E<CR>
T09FD026E80000008F74FAFFFF0382<CR>
T09FD026E80000008F74FAFFFF03E5<CR>
T09FD026E80000008F74FAFFFF0448<CR>
T09FD026E80000008F74FAFFFF04AC<CR>
16/11/2015 11:04:50.939 [RX] - T09FD026E80000008F74FAFFFF050F<CR>
T09FD026E80000008F74FAFFFF0572<CR>
T09FD026E80000008F74FAFFFF05D6<CR>
T09FD026E80000008F74FAFFFF0639<CR>
T09FD026E80000008F74FAFFFF069C<CR>
T09FD026E80000008F74FAFFFF0700<CR>
T09FD026E80000008F74FAFFFF0763<CR>
T09FD026E80000008F74FAFFFF07C6<CR>
T09FD026E80000008F74FAFFFF082A<CR>
T09FD026E80000008F74FAFFFF088D<CR>
16/11/2015 11:04:51.939 [RX] - T09FD026E80000008F74FAFFFF08F1<CR>
T09FD026E80000008F74FAFFFF0954<CR>
T09FD026E80000008F74FAFFFF09B7<CR>
T09FD026E80000008F74FAFFFF0A1B<CR>
T09FD026E80000008F74FAFFFF0A7E<CR>
T09FD026E80000008F74FAFFFF0AE1<CR>
T09FD026E80000008F74FAFFFF0B45<CR>
T09FD026E80000008F74FAFFFF0BA8<CR>
T09FD026E80000008F74FAFFFF0C0B<CR>
16/11/2015 11:04:52.765 [TX] - C<CR>
16/11/2015 11:04:52.767 [RX] - <CR>
16/11/2015 11:04:57.182 [RX] - <CR>
16/11/2015 11:04:58.684 [RX] - <CR>
16/11/2015 11:05:04.828 [TX] - C<CR>
16/11/2015 11:05:04.830 [RX] - <BEL>
16/11/2015 11:05:10.292 [TX] - S5<CR>
16/11/2015 11:05:10.298 [RX] - <CR>
<CR>
16/11/2015 11:05:18.387 [TX] - X1<CR>
16/11/2015 11:05:18.389 [RX] - <CR>
16/11/2015 11:10:08.836 [TX] - O<CR>
16/11/2015 11:10:08.837 [RX] - <CR>
T18EEFFFE8BD5865E72C96A0C02040<CR>
Reason: Inserted [code] tag for better readability.
Re: PCAN-RS-232 open CAN port hangs the CAN bus
Post by G.Lang » Mon 16. Nov 2015, 10:43
additional infos required.
-> What´s the CAN baudrate of your NMEA CAN system?
-> Is your CAN network terminated? What´s the termiantion value?
-> Which baudrate for the serial port do you use?
-> Is the LED from the module blinking 3 times after power up?
-> What´s about the power supply? Which voltage do you use?
best regards
