Labview: I can't send data with the example "SEND CAN data"
workhard10
Post by workhard10 » Fri 27. Nov 2015, 13:27
I can see the receiving data with the example "RCV CAN data", when PCAN-View is running/sending data to my device.
I want to send the same data with the example "SEND CAN data" instead of PCAN-View. After running I lost all my setting, and the The ID is always 3039, and LEN is always 8, the first data runs from 0 to 255, and the second data becomes 1, and first data count from 0 to 255 again (see my attachment) …… why? ....I don't understand :cry:
I look forward to your reply.
Lidong
SEND CAN data.pdf
(162.23 KiB) Downloaded 590 times
Re: I can't send data with the example "SEND CAN data"
Post by M.Maidhof » Mon 30. Nov 2015, 10:21
PCAN-View is not connected to a CAN hardware, see "nicht verbunden" in the status line. Please change the language to english, to understand the status line of PCAN-View.
workhard10
Post by workhard10 » Wed 2. Dec 2015, 10:08
M.Maidhof wrote:Hi,
sorry for the german labview version.
Must the PcanView.exe be connected, If I run the view?
I turn off the PcanView.exe and connct PEAK PCAN-USB optoentkoppelt to my relay card. the "Send example" sometimes runs, and sometimes not..., It stops quickly when I press the "run buttom". I must press many times, maybe one time it runs. It's very weird. Do you have any idea?
Post by M.Maidhof » Wed 2. Dec 2015, 10:51
yes, PCAN-View must be connected to a PCAN hardware or network, otherwise it will not work.
