Hi to all,
I have one proportion hydraulic valve on the machine that has some problems. It has 4 pin connector (+, -, HI and Low) 12VDC.
I would like to know If I can connect my PCAN-USB parallel to this connector and read received and transmited signals from machine to the valve and vice versa with PCAN-view?
Reading CAN data with PCAN-USB
- CAN.png (14.25 KiB) Viewed 7105 times
Re: Reading CAN data with PCAN-USB
The PCAN-USB need only CAN-H and CAN-L. Please add the termination always at the both ends of the CAN Line and keep the connection from the main CAN-Line to the other nodes as short as possible (like the lines to the PCAN-USB). Then start PCAN-View and connect to the CAN Bus with the used Baudrate.
- CAN-Simple.jpg (48.44 KiB) Viewed 7099 times
